Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #1
Old 21-08-17, 12:31 AM
RyzenMaster's Avatar
RyzenMaster RyzenMaster is offline
Newbie
Talking Asus Crosshair VI 1501 Official Bios Update
Hey Everyone,
Asus has just released the 1501 bios update with Overclocking improvements as well as an update to the keybot FW. Get on over to the Asus support site and give it a go.
Based on my initial tests;
1. Auras bugs are pretty much gone, but you may have to reinstall the SW;
2. Ryzen Master utility has actual accurate reporting of temps and speeds;
3. Post time for the board is a bit quicker.
  #2
Old 21-08-17, 07:13 AM
WYP's Avatar
WYP WYP is offline
News Guru
I have seen reports of this bios, but sadly we do not have the usual patch notes from Elmor. (I think he is on vacation).
Hopefully we will know exactly what has changed soon, as the "overclocking" bit is super vague.
__________________
_______________________________
Twitter - @WYP_PC
  #3
Old 21-08-17, 12:29 PM
Bartacus Bartacus is offline
OC3D Elite
When 1501 beta was first posted on OCN, Elmor said this:
New beta BIOS 1501
* Workaround for some CPUs stuck at 22x ratio if using override voltage
* Fixes PCIEX4 Bandwidth setting getting lost after power is removed
* Same DRAM boot behavior as 1403 (no cold boot fix)
* Same DRAM profiles as in 9920
* Still has the Vcore value issue when booting with Offset Mode and switching to Manual Mode
__________________
Guts: Ryzen 3900X / GB Aorus Master / 16GB TridentZ 3600CL15 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: Corsair Force MP600 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 240 rad / Heatkiller reservoir / dual D5 pumps
Tags
amd, asus, bios, crosshair, ryzen
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
