Go Back   OC3D Forums > [OC3D] Cooling Forum > Air Cooling
Thread Tools Display Modes
  #11
Old 26-06-17, 06:07 PM
ScottytooHotty ScottytooHotty is offline
Newbie
Originally Posted by AlienALX View Post
Colossus is junk. Had one, total junk.
Looked nice though.
I think maybe you either just had a bad case or for some reason or you just don't like Bitfenix cases but either way their cases are not junk, the Colossus most definitely isn't so if you can't give un-biased opinions probably best you don't bother.
__________________
Current Setup: Phanteks Enthoo Pro M Window Edition - i7 8700K OC @ 4.7ghz - ASUS ROG Strix Z-390-F gaming mother board - NZXT Kraken x72 AIO - 16gb Corsair Vengence RGB 3000mhz - Gigabyte Aorus 2080ti - 500gb 970 EVO M.2 - 250gb Sandisk M.2 - 250gb 850 EVO - 500gb and 1TB WD blue SSD - 1TB Seagate Barracuda - Corsair RM850x - Asus PG279 27" 165hz - Samsung 32" 4k - Glorious Model-O mouse - Corsair K70 RGB Keyboard - Logitech Z-5500 speakers - Blue Snowball mic.
  #12
Old 26-06-17, 09:28 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
unbiased? not at all. I had mine for over two years thanks. The plastic is cheap and thin. It clacks when you close the front for example. The coating is nice, but areas where it is not coated look like crap (like inside the lid for example). The only well made part on a Colossus is the inside, but that's steel so not hard to do.
Maybe when you've been into computers for 40 years and have owned hundreds, nae thousands of cases you can come back to me. Until then whatever. I'm entitled to my opinion.
I also had a BF Survivor and it was no better. The roof fan exploded on the first use. The blades were out of sync and one hit my Noctua. So BF sent me another case and the second one was no better. The roof fan made the rig move around on the desk. Again, cheap rubbish.
__________________
  #13
Old 27-06-17, 12:31 AM
Dark NighT's Avatar
Dark NighT Dark NighT is offline
OC3D Elite
I would recommend the Nzxt H440 ANY DAY, it is just about the best case i've ever had, and still very happy with it, all fans on 7v, 3 fans in, 3 out, silent and it easily handled the heatwave we had recently.
  #14
Old 27-06-17, 01:08 AM
Newbie
I have been "into" computers for over 22 years since I was 11 and built my first one when I was 14 and have built dozens over the years, I have plenty of experience in this thank you.
And yes you are entitled to you're opinion but the problem is this person is asking for advice and you are giving a totally biased view about issues you have had with a brand and just calling them junk even though that is not true, there are loads of review videos and articles about BF cases and most say they are very good.
I have owned two BF cases and have had zero issues with either, one of which is 4.5 years old and still has the original fans in and they are still quiet, the only thing I will say is in the colossus you'd be better off replacing the original 230mm fans with decent 140mm but that's only if you want to make it a tad quieter.
__________________
  #15
Old 27-06-17, 02:13 AM
AlienALX's Avatar
OC3D Elite
Here's my survivor.
Here is what happened the first time I ran the fan.
So Bitfenix not only sent me a replacement case (that was no better, BTW) they also sent me these.
Sorted, I thought. Just one problem, they were just as bad as the one that hit my cooler. Actually no, they weren't that bad, they got stuck on the 8 pin EPS instead.
In the end I had to remove both. Before I fitted my hardware into the new case I decided to test the fan. Because once you fit the roof fan and then the hardware you can't remove the fan. Fired up the fan from the PSU, case jumped around all over the place like a washing machine.
It turned out that the first case was twisted internally. This is why the motherboard posts did not line up etc. It wasn't damaged it was actually very well packed, it was just cheap junk.
The Colossus on the other hand? inside was as stiff as a post. Outiside let it down. Cheap thin plastic again (like the Survivor) door makes a horrible clack and like I said the plastic looks cheap and crap. Also, the side panel is poorly put together. It's all held in place with hot glue and nothing else, so the LED power socket failed after a few removals/replacement of the side panel.
Bitfenix make some of the best looking cases I have ever seen. Note - looking. When it comes to quality they are awful.
And it hasn't changed much. Last year a friend of mine bought the Pandora. He genuinely thought there was a mistake and that his one was a failed reject that had accidentally been re-boxed and sold by mistake. The edges of the alu were all rough, inside was twisted etc. So he sent it back and got a replacement - exactly the same.
Does that sound familiar? because my Survivor was the same.
I guess I am spoilt and very lucky, because I have had some really expensive cases. And when you work in those and then a Bitfenix you can tell that something isn't adding up.
So yeah, that's my opinion having owned in total 3 Bitfenix cases. I would never buy another (oh yeah and for cooling unless it's water the Colossus is crap also).
If you read reviews they all seem to agree with me about the quality too. Reviews were luke warm, even though the case looked spectacular in the dark and they don't make it any more so it can't have been that good.
__________________
  #16
Old 28-09-17, 12:55 PM
tech54K tech54K is offline
Newbie
I have learned a lot of things from this. Thanks!
Tags
case, cooling, fan
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
