Thread Tools Display Modes
  #21
Old 25-05-16, 06:24 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
looking nice but surely a cheaper option wold be a case from the breakers yard :P
__________________
ASUS Prime x370 Pro | Ryzen 5 1600 | Antec 240 AIO | Corsair Vengance RGB 3000 2 x 8Gb | Asus Strix RX 470 | Samsung Evo 120gb ssd | Seagate Baracuda 1tb storage | EVGA 500w | Phanteks Entho ProM Acrylic Window | Windows 10 and Linux Manjaro
  #22
Old 26-05-16, 09:36 AM
ciobanulx's Avatar
ciobanulx ciobanulx is offline
Advanced Member
While the rest of the case is being rusted. The Bitspower watercooling hardware has arrived
This is together with hardware for my AZUL Bitfenix Aegis build as well
  #23
Old 27-05-16, 03:25 PM
ciobanulx's Avatar
Advanced Member
Hi guys,
Here are most of the panels from the case rusted, clear coated and I also added some effects with some white paint smudges that I think turned out pretty nice and bringing the whole theme together for this build!
As you can see, compared to previous updates, it seems like the clear coat really darkened up the rust look however I think it looks even better this way and more in line with the Dead Space theme.
I'll be putting it all together very shortly but I wanted to give you guys a close up on all the parts!
Let me know what you guys think and stay tuned for more!
Cheers,
Alex
  #24
Old 27-05-16, 09:14 PM
SuB's Avatar
SuB SuB is offline
The Webmaster
Have to be honest, not dead sure on the white bits.. I'm not really sure what they add? They seem out of place to me? :P
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #25
Old 28-05-16, 03:58 PM
ciobanulx's Avatar
Advanced Member
Hi guys,
Here's the case all reassembled and looking as awesome as ever! I'm really happy with the result and it goes perfectly with the theme.
Still some effects to add over the rusted paint for a more Dead Space look and some things to build around the top and front panels.
Let me know what you guys think.
Thanks for checking it out and stay tuned for more!
Cheers,
Alex
  #26
Old 28-05-16, 08:51 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Looking damn fine there fella, but what's with all the white bits?
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #27
Old 29-05-16, 10:29 AM
ciobanulx's Avatar
Advanced Member
Thanks mate! Just wanted it to look more banged up and though the white adds a nice contrast. Once I add the blood effects it should blend in even more
  #28
Old 06-06-16, 10:09 AM
ciobanulx's Avatar
Advanced Member
Hi guys,
Sorry for the lack of updates on this build. I've been quite sick over the last week and haven't had a chance to post more updates.
The race is now on to finish this build by the 12th of June. That's Sunday this week as that's when the Cooler Master CaseMod World Series ends.
Here is the work I've done for the top and front panel.
If you haven't guessed it by now the front panel will have Isaac Clarke's helmet from the original Dead Space game mounted to it. It should look pretty nice if done right!
Let's have a look at the progress!
First up the helmet pieces. Started of with a piece of 2mm black acrylic. Measured and drew out the shape by hand.
If you can't see it yet, you will be the end of this update.
Next up were pieces for the top panel to work around the tube. Just designed a random pattern from scratch that I thought would look good and everything was cut by hand with my Dremel Moto-Saw.
Helmet pieces all cut too
I went ahead and bent the acrylic pieces to shape and mounted with other straight pieces to form the overall helmet design.
The way I bent them was with a sheet of thin aluminium that was used to measure the shape of the front panel and then taped up to hold that particular shape. Once done, the acrylic pieces for the helmet were placed in the middle individually and heated up until they took the shape of the aluminium sheet. Unfortunately I was too into it at the time and forgot to take pics.
You can see it coming together.
More work on the top panel. Mounting the pieces together.
And here they are both on the case.
More pics from the next day.
And lets not forget the finishing touches on the helmet
Let me know what you guys think! These will also be rusted which you will see once done.
Sorry if the quality of these images wasn't too good. They were all from my phone.
Cheers,
Alex
  #29
Old 07-06-16, 11:46 AM
ciobanulx's Avatar
Advanced Member
Bit more progress! Starting to get hardware in the case!
Also yesterday I forgot to mention that the full specs have been updated in the first post!
Here they are:
Case - Cooler Master MasterCase 5 Maker
Motherboard - ASUS Maximus VIII Extreme Assembly
CPU - Intel i7 6700K
Memory - 4 x 4GB Avexir ROG Certified Red Tesla 2400Mhz DDR4
GPU - 2 x ASUS STRIX GTX 980
SSD - 2 x Kingston HyperX Fury 240GB SSDs
PSU - Cooler Master V1000
Cables - CableMod Fully Custom Individually Sleeved Cables + MercoMods Custom Braided Extensions
LEDs - CableMod Magnetic RGB LED Strip
Radiators - Bitspower Leviathan Slim 240 Radiator, Bitspower Leviathan Xtreme 360 Radiator
Fans - CoolerMaster JetFlo 120mm Red and White LED fans
Pump - Laing D5 with Black Bitspower MOD Package - Pump Top + Casing
Reservoir - Bitspower D5 Top Upgrade Kit 150 with Cascade Tube Effect
Fittings - PrimoChill Revolver SX Matte Black + Various Bitspower Carbon Black angle fittings and extensions
Tubing - PrimoChill Copper Tubing
CPU Block - Bitspower Summit EF
GPU Block - 2 x Bitspower VG-NGTX980ADIIS
Thanks for checking it out!
Cheers,
Alex
  #30
Old 08-06-16, 01:51 PM
ciobanulx's Avatar
Advanced Member
Hi guys!
Here's the helmet nearly finished! Just some more minor details that will be added.
The light is only as an example from my phone, it will be better once on the build.
Also a quick rusty PSU mod. I didn't want to ruin the PSU so I used vinyl and rusted that. Then simply applied to the sides of the PSU and came out pretty well.
Cheers,
Alex
Tags
asus, case mod, cooler master, modding, watercooling
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
