Thread Tools Display Modes
  #11
Old 09-05-16, 07:27 AM
ciobanulx's Avatar
ciobanulx ciobanulx is offline
Advanced Member
Hi guys,
So here is the effect after about 24 hours once fully dried!
I gotta say I wasn't expecting this but it's the perfect effect I wanted for this build
It seems like applying in a straight even motion looks a bit better than the random pattern I did in the corner of the panel. Also the oxidising patina by itself didn't do much to the poweder-coating. I wonder how it would affect bare metal
Anyways, here are the result. Next up will be applying it to the case!
Thanks for checking it out!
Cheers,
Alex
  #12
Old 09-05-16, 10:37 AM
Tripp's Avatar
Tripp Tripp is offline
too many shrooms
this is epic so far, consider me subbed
  #13
Old 10-05-16, 07:21 AM
ciobanulx's Avatar
Advanced Member
Thanks a lot
  #14
Old 12-05-16, 09:58 AM
ciobanulx's Avatar
Advanced Member
Okay, here we go
Rust application applied to first parts of the case! I firstly scuffed everything with red scotch brite from MNPCTECH and on all plastic parts a clear plastic primer was applied.
I applied a much thicker coat than before and even let it run in some parts to get a better effect
Thanks for checking it out, stay tuned for the results
Cheers,
Alex
  #15
Old 14-05-16, 02:21 PM
ciobanulx's Avatar
Advanced Member
Hi guys,
Here are the results! Overall really happy with the way it's turning out.
I added some more patches of the rust paint in some areas I felt it didn't cover the panels too well.
Here I started to add more rust paint.
Let me know what you guys think of the results.
Cheers,
Alex
  #16
Old 14-05-16, 04:53 PM
steverebo's Avatar
steverebo steverebo is offline
OC3D Elite
Does that stuff have a solid surface or is it loose rust? I can imagine if it's loose rust it would be really messy to handle and risky if some strays onto any components.
Looks awesome though I'm a huge dead space fan so looking forward to seeing it come together
__________________
BeQuiet Darkbase Pro 900 | i7-7700K OC @ 5.10GHz | Custom water loop | ASUS MAximus Hero IX Z270 | Aurous Xtreme GTX 1080TI @ 2120mhz 12000mhz | 16GB Corsair Dominator Platinum @ 3200MHz CL15 | 500GB Samsung 960 Evo, 250GB Samsung EVO 850 | Corsair HX750I PSU | Windows 10 Pro 64-bit
  #17
Old 15-05-16, 07:39 AM
ciobanulx's Avatar
Advanced Member
Cheers mate
The rust is just like paint but a 'rust paint'. It's not loose or anything. It does however leave a rusty mark on your finger when you touch it as any rusted object would do. In the end I will clear coat it so should be all good
  #18
Old 18-05-16, 01:59 PM
ciobanulx's Avatar
Advanced Member
Hi guys,
Before I do any more rusting effects on the rest of the case I needed to do some pass-through holes for fittings as well as add some acrylic cover panels.
What I'm doing with the pass-through fittings going over the top of the case is trying to mimic the back of the Dead Space character with the tube and making this part of the loop.
I'm also tapping some holes on the back panel as this will mimic one of the arms of the character. You can see what I mean from the banner image.
Just to screw down acrylic panels that I will add.
I've also added some effect to the acrylic panels just with the Dremel disk
I'll be rusting everything now.
Stay tuned for more!
Cheers,
Alex
  #19
Old 19-05-16, 08:45 AM
SuB's Avatar
SuB SuB is offline
The Webmaster
Wow, that rusting is mental. Looks really cool, but totally alien to me lol. As for sealing it in, an old trick I would use when painting stuff that can be 'flaky' (read:weathering) is to clear coat with gloss to really seal it in properly and get a good couple of coats of that, then spray on a matt layer to bring it back to the original non-shiny finish. I always found that the best way to seal in the effect and not ruin it by making it shiny
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #20
Old 22-05-16, 02:22 PM
ciobanulx's Avatar
Advanced Member
Thanks a lot! That's a good idea, I'll see how I go. I purchased a lot of matte/satin clear coat and will try that on some parts first to see how it goes
Tags
asus, case mod, cooler master, modding, watercooling
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
