Thread Tools Display Modes
  #1
Old 27-04-16, 12:58 PM
ciobanulx's Avatar
ciobanulx ciobanulx is offline
Advanced Member
PROJECT ISOLATION (modded Cooler Master MasterCase 5 Maker)
Hi guys,
Been a while since I've been active on the forums
I've been super busy with a new job, move to a different city and pretty much a whole new life!
Glad to say that I'm back and with a very exciting project!
As the banner suggests it will be based on the Dead Space games and it's my entry for this year's Cooler Master Case Mod World Series as well as the ANZ Edition of the "World Series".
I am going all out with for this project and trying some modding techniques I haven't done before so stay tuned and enjoy the build log! I'm gonna give a little hint and say that this will NOT be a clean build
I would like to say a huge thanks to Cooler Master Australia for giving me this opportunity as well as ASUS Australia, Kingston HyperX, Avexir, Bitspower, Primochill, CableMod, PLE Computers and a new addition from a friend of mine, Kristian from MercoMods!
SPECS
Case - Cooler Master MasterCase 5 Maker
Motherboard - ASUS Maximus VIII Extreme Assembly
CPU - Intel i7 6700K
Memory - 4 x 4GB Avexir ROG Certified Red Tesla 2400Mhz DDR4
GPU - 2 x ASUS STRIX GTX 980
SSD - 2 x Kingston HyperX Fury 240GB SSDs
PSU - Cooler Master V1000
Cables - CableMod Fully Custom Individually Sleeved Cables + MercoMods Custom Braided Extensions
LEDs - CableMod Magnetic RGB LED Strip
Radiators - Bitspower Leviathan Slim 240 Radiator, Bitspower Leviathan Xtreme 360 Radiator
Fans - CoolerMaster JetFlo 120mm Red and White LED fans
Pump - Laing D5 with Black Bitspower MOD Package - Pump Top + Casing
Reservoir - Bitspower D5 Top Upgrade Kit 150 with Cascade Tube Effect
Fittings - PrimoChill Revolver SX Matte Black + Various Bitspower Carbon Black angle fittings and extensions
Tubing - PrimoChill Copper Tubing
CPU Block - Bitspower Summit EF
GPU Block - 2 x Bitspower VG-NGTX980ADIIS
For now I'll start with the packages received from Cooler Master
A mysterious box (though the thread title might hint at what's inside)
JetFlo fans and a V1000 power supply
Stay tuned for more guys!
Cheers,
Alex
  #2
Old 01-05-16, 01:23 PM
ciobanulx's Avatar
Advanced Member
Hi guys,
Here's a look at the glorious CoolerMaster Master Case 5 Maker! A good improvement from the 5 Pro
New integrated fan controller and LED controller with one red LED bar included.
The front section is easily removable with clips at the bottom and magnets at the top, revealing the front intake mesh and 5.25" bays. The front panel is also padded with sound dampening material.
Sound dampening cover for the top as well with air still being able to be exhausted through the back or front sections of the top panel.
The top sound dampening cover can be removed, with clips towards the front and magnets in the back.
The top slide on cover now has integrated magnets as well, towards the front for a better grip.
The included magnet LED bar. This one is red and not sure if case will come included with different colours.
Thanks for checking it out and stay tuned for more guys!
Cheers,
Alex
  #3
Old 02-05-16, 11:06 AM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
Ohh boy, another build log. Nice!
I'm subbed!
  #4
Old 02-05-16, 11:19 AM
WYP's Avatar
WYP WYP is offline
News Guru
subbed, I look forward to seeing what you can do with the case.
__________________
_______________________________
Twitter - @WYP_PC
  #5
Old 02-05-16, 11:51 AM
ciobanulx's Avatar
Advanced Member
I'm subbed!
Thanks a lot guys
  #6
Old 02-05-16, 12:06 PM
ciobanulx's Avatar
Advanced Member
Hi guys,
I'm prepping the case for painting but doing some mods first
Ignore the smaller scratches, I was just trying something. The paint will cover all that and might even stick better now :P
The large scratch looking cuts were done with the dremel! The melted plastic is exactly the effect I wanted. Once it's all painted you will see
Let me know what you guys think so far and stay tuned for more!
Cheers,
Alex
  #7
Old 05-05-16, 11:40 AM
ciobanulx's Avatar
Advanced Member
Hi guys,
I have another update for you!
This time showcasing the Cooler Master V1000 power supply as well as the JetFlo fans!
The fans are red and white LED, I got more than I needed as I'm not sure how I'm gonna combine the colours in the build.
Also, the banner has been update with PLE Computers joining as a sponsor! PLE Computers is one of the best online computer store in Australia with lots of variety for water cooling on top of all the normal components. They even stock Linus' special edition Noctua fans as well as the LTT hoodies. If you're an aussie, check them out if you haven't already https://www.ple.com.au/
Some pretty powerful fans but they also come with voltage reducers for lower RPM and noise
As we as proprietary screws for the anti-vibration soft corners on the fans which are removable.
With these fans the LEDs are in the middle with the light shining towards the edges creating a nice effect.
All black and sleeved cable
Thanks for checking it out guys and stay tuned for more!
Cheers,
Alex
  #8
Old 08-05-16, 02:29 PM
ciobanulx's Avatar
Advanced Member
Hi guys,
I've got an exciting update for you today
Since this is a Dead Space theme I'm looking at a different painting technique for the entire case!
So I'm testing out this rust paint to see if it's the effect I'd like to go for in this build as well as learning how to apply it. Luckily I have quite a few spare case panels laying around.
The idea with this is that it can be applied to anything, even plastic and rust that too. It's a metal based paint which you apply with a brush and leave it to dry for about 1 hour. Once dry you apply the oxidising patina which is a form of activator that speeds up the rusting process. Leave it for a few good hours and you should have a nice, real rust effect.
So tonight I've applied it to a spare case panel. I did a few different areas where I applied it on straight as well as in a random pattern to see if it gives a different effect or if it even matters how you apply it. I've then applied the activator and leaving it overnight. I've also applied the activator to a part of the panel with no metal base paint as technically this should rust metal by itself too, however it might not go through the powder coating on the panel.
This is the stuff and how it looks after about 30 min since the activator was applied. I'll show you guys the effect tomorrow once it fully dries.
This is the rust base applied.
This is once dried.
And this is the Oxidising Patina applied.
Applied some more as the more you have on and the longer it stays wet for, the more intense the effect will be.
You can already see it starting to rust here.
This is after about 30 mins with the activator applied.
We'll see the full effect tomorrow once it dries.
Hope you guys have enjoyed this update! I'm definitely really excited for this entire project!
Thanks for checking it out.
Cheers,
Alex
  #9
Old 08-05-16, 05:00 PM
Buddy3012 Buddy3012 is offline
Newbie
What a dirty job^^
  #10
Old 09-05-16, 07:26 AM
ciobanulx's Avatar
Advanced Member
Originally Posted by Buddy3012 View Post
What a dirty job^^
Yea that's how it's meant to be :P
Tags
asus, case mod, cooler master, modding, watercooling
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
