Go Back   OC3D Forums > [OC3D] Cooling Forum > Air Cooling
Thread Tools Display Modes
  #31
Old 25-07-15, 07:32 PM
shambles1980's Avatar
shambles1980 shambles1980 is offline
OC3D Elite
you have 2 main options.
1 wire a resister in line, *these are sold specifically to reduce fan voltage form 12v to 7v or 8v or some other value depending on the resister.
2 Wire in a potentiometer. which is just a variable resister, these come in many different types, so have a look for them.
but again you do seem to be spending money on fans when a case would have been a better option.
__________________
i7 2600, intel dz77sl-50k, 16gb 1600 DDR3, 900d case, gtx 780 @ 1306/1727 "xspc block", 1x 240 1x360 1x480 rads 2 bay res, http://www.3dmark.com/3dm/14829772
  #32
Old 27-07-15, 01:44 PM
tolagarf's Avatar
tolagarf tolagarf is offline
OC3D Crew
There are many ways to cool a PC. I guess most use the brute force method with noisy fans and high dust build up, yet the cooling is very effective. I tend to go for positive static pressure pushing small amounts of air into the cases though as many sources as possible (noctua fans), and then pull it out through the top with a slightly larger fan.
Works well for me, which means my PC is dead silent under idle and minimal use and there's hardly any dust coming in, as the heat is pushed out through all those small holes around the case, instead of being pulled in.
  #33
Old 27-07-15, 03:35 PM
Davva2004's Avatar
Davva2004 Davva2004 is offline
OC3D Elite
It's very easy to rewire a molex to lower fan speed, at the moment your fan will be wired to yellow (12v) and black (0v) to run the fan at 12 volts. Just move the pin that currently connects to the black wire to the red wire (5v). That way your fan sees a voltage that is the difference between 12v and 5v, which is 7v. You still get good airflow but you get less noise. I run all my fans at 7v by doing this.
__________________
  #34
Old 27-07-15, 05:04 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
As Davva2004 said, rewiring fans is easy peezy
I cover all possible pinouts in the Pinouts Request thread.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
Tags
airflow, cooling, fan, heat, temperature
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
