Go Back   OC3D Forums > [OC3D] Cooling Forum > Air Cooling
Thread Tools Display Modes
  #21
Old 18-07-15, 12:21 PM
shambles1980's Avatar
shambles1980 shambles1980 is offline
OC3D Elite
yep that case is a bit small... you would probably need delta fans as case fans too keep that thing running cool on air
cant even really see any realistic way to shoe horn a 240 rad in there.
__________________
i7 2600, intel dz77sl-50k, 16gb 1600 DDR3, 900d case, gtx 780 @ 1306/1727 "xspc block", 1x 240 1x360 1x480 rads 2 bay res, http://www.3dmark.com/3dm/14829772
  #22
Old 18-07-15, 02:23 PM
Merak Merak is offline
Newbie
Ok, so I moved the Hard Drive around and made the cables go round the back and at the moment my temps under load reach 50-60C° on the CPU and about 70C° on the GPU after about 20min. No idea how it would develop after longer times :-). First of all: Is this ok, or is it still too hot? I could get a new case, but first I would like to try getting the most out of my current one. Now I read that there are fans that one can install like an extension card next to the GPU or like a Hard Drive/CD-Drive. Are these any good?
  #23
Old 18-07-15, 03:33 PM
OC3D Elite
Your biggest problem is you are mostly circulating the hot air in the case rather than removing it and repplacing it with cool air.
little spot fans do help in generall for cooling down a problem heat source.
but its still only pushing the hot air arround. if you cant get that hot air out of the back of the case, and replace it with nice cool air at the front then you will only ever see increasing temps in the case.
__________________
  #24
Old 18-07-15, 03:43 PM
Newbie
http://www.amazon.de/Leistungsstarke...l%C3%BCfter+pc
According to this one, hot air is pumped out. I guess I could give it a try...
  #25
Old 18-07-15, 03:54 PM
OC3D Elite
I think something like this would be more effective.
http://www.frozencpu.com/products/25...SL-PCI-02.html
but again you still really need to get the cold air in to push the hot air up so it vents out of your rear mounted exhaust fan.
if yor just exhausting from a pci slot that is relitivly low down then you are probably removing more of the colder air than you are removing hot air.
then again if you are going to start throwing money at fans, then you may want to seriously consider looking for a second hand cooler master haf case i have a 922. and it does have prety damn decent air flow and good fan mounts.
Obviousli i tried to fill it with rads.. But its better for fans
What kind of fan do you have in the front of your case, and does it even have an intake option at the front?
__________________
  #26
Old 18-07-15, 04:01 PM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
That's just gonna pull the air away from your graphics card.
The sad reality of it is that you can only do so much with your case. That said, the load temps seem reasonable actually. But as said that was only for 20 minutes and your system has a lot of trouble get the warm air outside of the case so it'll just heat up more and more.
Another thing you could try is buying another CPU cooler which is a tower cooler (like the 212 Evo) that will direct the warm airflow from the CPU to the rear fan rather than just spreading it around the case. But then again that's gonna cost more than a fiver.
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #27
Old 18-07-15, 04:03 PM
JR23 JR23 is offline
OC3D Elite
Your current temps sound pretty good for a 25°C ambient especially considering your cooling hardware. I wouldn't be too concerned at all.
If you have to get improvements then I think the case is the first thing to change rather than wasting money on additional little silly PCI slot fans.
JR
  #28
Old 19-07-15, 01:36 AM
AMD Enthusiast
JR
My thoughts exactly!
Instead of trying to fix an issue that's inherent to your case, it's better to just get a new one that's won't always limit you
  #29
Old 19-07-15, 12:49 PM
Davva2004's Avatar
Davva2004 Davva2004 is offline
OC3D Elite
I can strongly recommend the Bitfenix Neos as a cheap but cool case, it has space for two 120mm intake fans at the front behind foam and mesh filters, and one 120mm exhaust fan at the top. No side vents or silliness like that. The power supply is bottom mounted and has its own filtered intake.
You can get it in a variety of colours and with or without a side window.
They start at around £30.
I have two Corsair AF120 LED fans at the front at 7v with the stock Bitfenix fan at the back at 12v and everything stays cool, quiet, and dust free.
https://www.overclockers.co.uk/searc...ortby=priceAsc
__________________
  #30
Old 25-07-15, 12:39 PM
Newbie
Ok, first of all: thanks for all the answers. I gave one of those CD-Drive-Cooler-Thingies a try and it actually looks like it worked. My CPU rarely goes above 50-55°C and the GPU stays around 60-70°C. The fans never need to accelerate, wich means my PC is quieter under load. But there is one disadvantage: The new fan lacks fan controll and to some extent is a little loud. So under load the PC is quieter, but on idle I have that annoying base-sound. So I have one last question: Is there any possibilty to get some controll on a fan with a molex-cable, so I can switch it of when i don`t need it? (its connected directly to the PSU)
Tags
airflow, cooling, fan, heat, temperature
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
