Go Back   OC3D Forums > [OC3D] Graphics & Displays > Overclocking
Thread Tools Display Modes
  #11
Old 26-02-15, 09:24 PM
AMD Enthusiast
Originally Posted by Burlyleader View Post
Yeah and I would like to get the best I can get so I will have to think about it. The issue I seem to have is the programs and tools that some of these cards come with, like the cards I have now I use Asus GPU Tweak, the program is pretty well rounded in my opinion. I'm just wondering how the MSI program is overall.
Another thing is: Can the card be liquid cooled and does it have a compatible waterblock because I hope in the coming months to get my loop all set up and running.
Should have mentioned this earlier Well if you are watercooling then look for cards that have a reference PCB. Any reference card would do but if you wanted to get the best air cooled card then you could too so long as you can find the right block for it. The Vapor-X and lightning are the only cards off the top of my head the needs a custom block because its a custom pcb
I use Afterburner for AMD cards. Solid and on my brothers PC he uses Asus Tweak because of his Asus card but tbh i don't like it in comparison.
Tags
amd, benchmark, gpu, overclocking, stress test
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
