Go Back   OC3D Forums > [OC3D] Cooling Forum > Air Cooling
Thread Tools Display Modes
  #21
Old 13-08-14, 06:21 PM
Innocent159's Avatar
Innocent159 Innocent159 is offline
OC3D Elite
Originally Posted by MaddenShadow View Post
They were probably mistaken. Unless its a reference card, all air is dumped into the case.
Originally Posted by RamboOC View Post
Your gpu fans heat out out inside the case,
stock factory gpu blower cooler pushes air out outside the case
inside the case, from what side top or side by the power input?
__________________
I don't want a sig anymore
  #22
Old 13-08-14, 06:36 PM
RamboOC RamboOC is offline
Suspended By Request of Police
Edit: fixed image. my graphic tablet wouldnt work so i had to use mouse
This is what i meant, and why you want more exhaust fans
  #23
Old 13-08-14, 06:40 PM
OC3D Elite
I never said I want more, I want a subsequent answer to every once disagreement.
initially top fans ere intake and when I swap it temps has improve... The rest stayed the same.
my max temp (atm) is 30*C constant (just web browsing). top 50% (exhaust), side 50% (intake), front 100% (intake), rear 50% (intake)... I'm happy, what is your current set up?
__________________
  #24
Old 13-08-14, 07:07 PM
Cant find my memory card for the camera but here is an old pic without the fans i found on hwbot of my old setup (but gpu,psu,case is the same)
Keep in mind that my current pc is super crap (look at my sig) and the case is just terrible.
I have a Gigabyte GTX 570 Super Overclocked edition With 3 fans on the gpu cooler exhausting the hot air into the case.
I use 2 x 40mm fans at the back as exhaust and one 90mm (or 80mm?) fan as an intake at the front. nowadays i tend to run my pc without side panel so it doesn't make that much diffrence
  #25
Old 13-08-14, 07:09 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
A little more accurate on the non reference cards.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #26
Old 13-08-14, 07:12 PM
I don't have patience for photoshop today every little thing not working makes me go mad
  #27
Old 13-08-14, 07:19 PM
OC3D Elite
You need too *cool down*
So top intakes (x2) and side exhaust (x2) and rear exhaust would work better?
__________________
  #28
Old 13-08-14, 07:21 PM
shambles1980's Avatar
shambles1980 shambles1980 is offline
OC3D Elite
you may be surprised just how much heat your psu is also exhausting being so close to the heat sink.
  #29
Old 13-08-14, 07:26 PM
MadShadow MadShadow is offline
OC3D Elite
DOnt you have front intakes? Top intakes is never really good
__________________
|i5 4460|8GB RAM|R9 380 4GB|ASUS Z97-I Plus|WD Blue 1TB|Corsair RM650|Phanteks Enthoo EVOLV ITX|
  #30
Old 13-08-14, 07:30 PM
OC3D Elite
yes one and oh yes there is an filter on
__________________
Tags
case, cooling, exhaust, fan, intake
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
