Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
Thread Tools Display Modes
  #51
Old 12-06-14, 09:25 AM
SieB's Avatar
SieB SieB is offline
OC3D Elite
lol, try putting 1.4v through a 4770k and not having it melt. The 4790k has 1.4v going through it and temps are still ok.
__________________
NZXT Switch 810 - Ryzeny 3600 - Gigabyte X570 Gaming - 32GB Corsair Platinum SE - MSI Gaming 1070 - Crucial MX100 256GB SSD - Crucial MX500 500GB SSD - Samsung F3 1TB HDD - Corsair H100 - Corsair RM1000i SE - Asus VE247H
PC Audio: Asus Xonar STX - Sennheiser HD650.
Portable Audio: FiiO X3II - Audiofly AF140 - Etymotic ER4s - Fidue A83.
  #52
Old 12-06-14, 10:08 AM
Agost's Avatar
Agost Agost is offline
OC3D Crew
A conventional thermal paste on a delidded 4770K can lower overall load temperatures by ~10 degrees and with CLU/CLP you can hit 20 degrees less peak temp.
Tomshw test with both cpus @ 4.2 GHz and 1.275V shows that there's just 6C of deltaT between 4770k and 4790k load temps
Moreover I'd never advise someone to keep a 22nm cpu at 1.4V for a daily OC.
  #53
Old 12-06-14, 10:19 AM
SieB's Avatar
OC3D Elite
This is with a delidded CPU though, i'm not saying the thermal paste Intel use is better than other thermal paste you can buy. Just that the stuff they are using on the 4790k is better than what they were using on the 4770k.
Toms test with both cpus @ 4.2 GHz and 1.275V shows that there's just 6C of deltaT between 4770k and 4790k load temps
This is at a relatively average voltage though, as you increase the voltage the difference in delta would be larger. Although 1.4v isn't a safe 24/7 voltage it shows how much cooler the 4790k runs at higher voltages compared to the 4770k. If you put 1.4v through a 4770k it wouldn't stay under 85*c and would go into the 90's.
__________________
  #54
Old 12-06-14, 12:38 PM
MacLeod's Avatar
MacLeod MacLeod is offline
OC3D Elite
Lightbulb
Originally Posted by Dicehunter View Post
Either way I don't really see the point in this release, Would of been better to just put those resources towards the next REAL performance jump.
Im now of the belief that this release was done just to sale some backstock 4770K's. They're the exact same die and a guy on HardOCP identified the date code on the ES as being built in August of last year! I think they slapped some extra caps on the back and maybe tinkered with the TIM a little and called it "next generation", built in a lot of hype and hoped they'd clear out some slow moving inventory. Makes me think they don't pay attention to this community at all and forgot about all these review sites and how the truth would get out about these things before they were released.
Still, as a refresh, and that's all DC is, it's still a great chip. So it won't hit 5.0, that does suck but a 4790K running at a stable 4.7 GHz is still a whole lot of CPU horsepower and still worth buying if you're in the market for a Haswell level upgrade. And considering it's not supposed to cost any more than a few dollars more than a 4770K, I see no real harm done other than to Intel's marketing department.
__________________
AMD R5 1600X @ 4.0 GHz ••• Asus ROG Strix X370-F ••• Corsair H110i
Corsair 500R ••• EVGA Supernova G3 750 ••• Corsair Vengeance 16GB
Western Digital Caviar Black 1TB x2 ••• Nvidia RTX 2070 FE
Samsung 840 Evo 250GB ••• Acer Predator XB272 @ 240 Hz
Logitech G-Pro TKL ••• Logitech G MX518
  #55
Old 12-06-14, 06:28 PM
Zoot's Avatar
Zoot Zoot is offline
OC3D Elite
I'd be surprized if they weren't.
In the industry you don't tape-out new die if you don't have to. New mask-sets aren't cheap. Intel's in a much better position since they don't have to pay TSMC's margins but it still is a high cost for them. It's the reason you've the same Haswell die in everything to low end entry level laptop right up to the flagship desktop 4770k. AMD is the same too.
__________________
Desktop: AMD Ryzen 7 3700X | X570i Aorus | 32GB Corsair DDR4-3200MHz | RX 5700 XT | Aorus PCIe 4.0 1TB M.2 | Fractal Define Nano S
Home Server: AMD Ryzen 3 2200G | Asus Prime B450M-A | 16GB Crucial DDR4-2400MHz | 39TB | Fractal Design Define R5
HTPC: AMD Athlon 5350 | ASRock AM1H-ITX | 4GB Corsair DDR3-1333MHz | MiniBox M350
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
