Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
Thread Tools Display Modes
  #21
Old 09-06-14, 04:22 AM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
My bad, They actually reached 4.70GHZ but with 1.36v, Sample straight from Intel.
Still though even if that's an average sample or even a poor sample that shouldn't happen when it's being touted as an "overclocking chip".
I wish they would of just skipped this stupid "Re-hash" and focused on proper upgrades instead of adding a few more capacitors and newer TIM to an existing CPU.
We need real progress not these incremental updates.
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - RTX 2080 Ti @ 2000/7500 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #22
Old 09-06-14, 04:44 AM
cooperman's Avatar
cooperman cooperman is offline
OC3D Crew
Meh the VRM management is still on the cpu's die, no amount of changeing the tim or adding spaceage polymer is going to change the fact that its going to make the cpu run hot and the oc'ing is going to suffer.
Thay need to stop that give that job back to the motherboard.
__________________
i5 4690-Gigabyte Z97P-D3-16Gbs 1866Mhz Kinston HyperX Fury Black-Asus GTX 980 Corsair h80i-sandisk 256gb ultra plus-250gb Intel SSD-WD Blue 500gb-Seasonic M12-620w-Cooler master haf xb.
  #23
Old 09-06-14, 09:55 AM
nepas's Avatar
nepas nepas is offline
OC3D Elite
Originally Posted by Dicehunter View Post
Best bet is to wait for Broadwell even if your still on Sandybridge.
The way things are going I may stay with my Sandy until Skylake/Cannonlake.
__________________
reserved,this space will host my BC2 sig,once I learn to shoot,err scratch that,when I learn to stop getting shot
  #24
Old 09-06-14, 10:51 AM
WYP's Avatar
WYP WYP is offline
News Guru
Your forgetting that the temps of the PCPER DC sample was less at 4.7GHz @ 1.37v than the normal Haswell as 4.8ghz @ 1.25v, an impressive temperature decrease. With DC i would actually be comfortable running the chip at voltages above 1.3v.
As I said before DC should only be considered a decent upgrade by people with Sandy bridge or lower processors, well sandy is a bit of a streach perhaps.
For Haswell users, Devils Canyon is a side grade at best. It is definately worth buying over vanilla Haswell, but not worth switching out your haswell chip for.
__________________
_______________________________
Twitter - @WYP_PC
  #25
Old 09-06-14, 10:59 AM
SieB's Avatar
SieB SieB is offline
OC3D Elite
I think people have the wrong idea about DC, they aren't a performance upgrade, they are just a Haswell refresh with better thermals.
I don't know why people are expecting them to be faster, that is not what these CPUs are aiming to do it is pretty obvious it isn't for upgrading to.
Well unless your main intention is for overclocking or if you are buying new.
__________________
NZXT Switch 810 - Ryzeny 3600 - Gigabyte X570 Gaming - 32GB Corsair Platinum SE - MSI Gaming 1070 - Crucial MX100 256GB SSD - Crucial MX500 500GB SSD - Samsung F3 1TB HDD - Corsair H100 - Corsair RM1000i SE - Asus VE247H
PC Audio: Asus Xonar STX - Sennheiser HD650.
Portable Audio: FiiO X3II - Audiofly AF140 - Etymotic ER4s - Fidue A83.
  #26
Old 09-06-14, 11:07 AM
Permafrost's Avatar
Permafrost Permafrost is offline
Compo Whore
having a read about this re-hash rubbish, i'm on haswell got a cpu that can hit 4.9 (unstable) but it get 4.8 easy but only run it at 4.4
so i'm going to stay with this cpu till Cannonlake or after..
__________________
  #27
Old 10-06-14, 03:59 AM
MacLeod's Avatar
MacLeod MacLeod is offline
OC3D Elite
Looks like it's a dud. Both HardOCP and PC Per have reviews out saying they can't get passed 4.7 GHz and are using high 1.35V. PC Per used a H80i but [H] used a high end Koolance system and still couldn't get passed 4.7. Guess I'll just drop a FX 8350 in and ride out the next hear and see what comes out.
http://www.hardocp.com/article/2014/...y#.U5Z7sZZyfFo
http://www.pcper.com/reviews/Process...d-Overclocking
__________________
AMD R5 1600X @ 4.0 GHz ••• Asus ROG Strix X370-F ••• Corsair H110i
Corsair 500R ••• EVGA Supernova G3 750 ••• Corsair Vengeance 16GB
Western Digital Caviar Black 1TB x2 ••• Nvidia RTX 2070 FE
Samsung 840 Evo 250GB ••• Acer Predator XB272 @ 240 Hz
Logitech G-Pro TKL ••• Logitech G MX518
  #28
Old 10-06-14, 04:21 AM
Dicehunter's Avatar
Resident Newb
Good morning, Yeah I just saw this, After Intel sees this they will most likely send the other reviewers cherry picked samples, Just you wait and see, OC3D is going to get a golden sample and then it's going to get the gold award
Your going to like the 8350 though, Great chip, Very little between it and Intel in games, Benchmarks are another story but in my eyes games are more important than benchmarks
__________________
  #29
Old 10-06-14, 05:47 AM
Zoot's Avatar
Zoot Zoot is offline
OC3D Elite
Well that certainly doesn't look good, given you'd imagine the reviewers would be the ones getting the cherry picked ones as is. I guess we'll have to wait and see what other reviewers throw up. I'd still buy it myself were I in line for an upgrade given the higher clock frequency but I don't really care about overclocking.
And say what you like about the FX-8350, but it does overclock quite well. I can coax 5.2GHz out of mine.
__________________
Desktop: AMD Ryzen 7 3700X | X570i Aorus | 32GB Corsair DDR4-3200MHz | RX 5700 XT | Aorus PCIe 4.0 1TB M.2 | Fractal Define Nano S
Home Server: AMD Ryzen 3 2200G | Asus Prime B450M-A | 16GB Crucial DDR4-2400MHz | 39TB | Fractal Design Define R5
HTPC: AMD Athlon 5350 | ASRock AM1H-ITX | 4GB Corsair DDR3-1333MHz | MiniBox M350
  #30
Old 10-06-14, 10:20 AM
barnsley's Avatar
barnsley barnsley is offline
born in a.....
Implying that you can still buy 8350s that could do that . F*** the 9590. Taking all the decent 8350s out of the proper price point. I still need to really push my 8320 now its not my main machine.
__________________
Rig: i7 [email protected]|2x8gb HyperX Fury|Intel z97-AR|Corsair H75| 2x Nvidia 1070 founders edition|Superflower leadex 750W gold|Inwin 904| 970 EVO 500GB m.2|512GB evo 840| Crucial MX 500 500GB|ASUS MG279Q +Acer S240HL| Windows 10 pro, 8.1 pro| Kubuntu LTS
Audio: Silverstone EB01-E+EB03+DT 770 Pro 250Ω+Samson SAGOMIC
Ducky Legend (cherry red)+Zowie AM-FG
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
