Thread Tools Display Modes
  #11
Old 23-02-14, 08:49 PM
Innocent159's Avatar
Innocent159 Innocent159 is offline
OC3D Elite
Originally Posted by Feronix View Post
The CPU has no iGPU and it's really cheap so a decent GPU should fit in the budget. An R7 260x (which I think is an HD7770 rebadge) would be fine at 1080p with low-med settings but if you can fit a better one in it's always... better!
Edit; What about that new R7 265?
would like to buy an aftermarket cooler if I get the cost lower.. so ill keep the gpu and maybe ho for the amd processor
__________________
I don't want a sig anymore
  #12
Old 23-02-14, 08:52 PM
RamboOC RamboOC is offline
Suspended By Request of Police
I guess you fell in love with firefox
  #13
Old 23-02-14, 08:57 PM
OC3D Elite
not funny...
__________________
  #14
Old 23-02-14, 09:05 PM
back on topic, i have amd a6-6400k apu ("dual core") (richland 2nd gen apu) and a dedicated gpu, and i can say that the cpu bottlenecks and causes stuterring in bf4, so i have to close as many other programs as i can. overclocking to 4.3ghz reduced amount of stuttering but it is still not as good as i want it to be. so if you want to go with apu, try to buy the quad core higher end ones
  #15
Old 23-02-14, 09:12 PM
OC3D Elite
The reason why I choose Intel over AMD. I don't think the i3 would bottleneck
__________________
  #16
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
The 750k and 760k are higher end APUs (A10 I think) without the GPU on them. That makes them cheap and they actually out-perform the FX series chips of the same price.
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #17
Old 23-02-14, 09:14 PM
OC3D Elite
will look through comparisons and reviews tomorrow and come back with a decision or we could have an Intel-AMD war
__________________
  #18
Old 23-02-14, 09:20 PM
Feronix's Avatar
OC3D Elite
An i3 won't be a bottleneck, but will be slightly more expensive. I'm an Intel user myself, but in the low-end/ budget segment AMD is usually the way to go imo.
__________________
~Rick
  #19
Old 23-02-14, 09:27 PM
760k and 750k almost score twice as better than my a6-6400k in benchmarks.
  #20
Old 24-02-14, 04:17 AM
OC3D Elite
does 750k bottleneck?
My daddy made it clear NO BOTTLENECK. He want smooth and clear gaming. His a FPS fan and loves reality looking games. I'l make the suggestion of my build and tel him why I choose the component maybe he understand. (budget currently at R7 264)
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
