Thread Tools Display Modes
  #21
Old 09-02-13, 07:22 PM
seumasbeathan seumasbeathan is offline
Banned
For some cables give Pexon a shout
  #22
Old 09-02-13, 10:08 PM
berthez berthez is offline
Member
looks awesome man
__________________
My mATX Rig
Nvidia GTX TITAN 6GB | Intel i7 3770K | Lian Li PC-V600FB
ASUS Maximus V Gene | Corsair Dominator Platinum 16GB DDR3 1866 | Intel 120GB SSD
http://forum.overclock3d.net/showthread.php?t=53976
  #23
Old 10-02-13, 10:05 AM
(SS)Stu (SS)Stu is offline
Newbie
Thanks i will do!
Originally Posted by berthez View Post
looks awesome man
Cheers
  #24
Old 10-02-13, 10:29 AM
Newbie
Mylar in silver would look perfect i think. Just not sure whether the braid is thick enough. Wouldn't want the cable color to show through!
  #25
Old 12-02-13, 01:27 PM
Newbie
Progress Report 2
Progress Report 2
Just got some more stuff for my build today and most excitingly got my CPU waterblock!
Here is the 200mm Spectre PRO with white LED. This will be going into the front of the case to supply a quite but yet copious amount of air flow into the case. Also to light up the pump and res area slightly.
The 120mm Spectre PRO with white LED. This will vent hot air from motherboard out the back of the case. Also providing subtle lighting for the motherboard.
A short 15cm SATA cable to connect to the SSD on the PSU backpanel. I will be sleeving it either a golden or silver color.
Two silver pre-sleeved molex fan connectors to connect upto 3 fans each.
With free bag of Hariobo tangy sweets . Courtesy of OverclockersUK "SUGARRUSH"!!!
And the peace de la resistance. The EK-Supremacy Elite - Full nickel waterblock
I know its overkill for a i5 but i think it will look great!
  #26
Old 12-02-13, 02:12 PM
AverageNinja's Avatar
AverageNinja AverageNinja is offline
Average Penis Too
That waterblock isn't overkill for an i5 mate
There is no overkill waterblock for an i5. It's like an i7 without hyperthreading
__________________
JavaBean: Ryzen 5 1600 / Corsair ML240L RGB / ASUS Crosshair 6 Hero / 16GB Corsair LPX / ASUS RX 580 Strix / Corsair RM750X / Fractal Design Meshify C
OC3D Overclockers Club Member:
Nr. #00 (Club Owner)
  #27
Old 13-02-13, 07:11 PM
polarbeardav polarbeardav is offline
Newbie
That's basically what it is. Just a binned i7 with slightly less prowess.
Edit: That sounded like it came off harsh (especially since I'm a new member). It was more of an reuse what you can kinda thing :P
  #28
Old 13-02-13, 09:56 PM
Newbie
You mean to say Intel are cowboys... lol be careful what you say Intel will control the world soon so they might hunt you down for that comment! lolz
  #29
Old 13-02-13, 10:06 PM
Newbie
Progress Report 2.1
Progress Report 2.1
Just some pics to show how my front and rear fans look in the case:
My camera-phone doesn't show the light from the fans very well. With the naked eye they look brilliant white. I'll try get some night shots of the light.
  #30
Old 14-02-13, 05:04 AM
Mark3Max Mark3Max is offline
OC3D Crew
Hi (SS) Stu, your build looks great so far . I think the black and silver color scheme will look great in that case . The silver mylar braiding on all the cable would look epic. Have you decided what rad your putting in the roof ? And are you going to watercool you video card ? I know that pretty much depends on whether your going to wait on the new cards come out . Your idea will look great when your done.
__________________
Corsair 650D, MSI Z77A-GD65 , I7-3770k, Corsair H100i w/sp120 QE ,G.Skill Ares 16gb 2133 c9, Asus Blu-Ray Burner, Asus Xonar STX ,Corsair Neutron GTX 240gb ,W.D. black 1TB ,Seagate 3TB, MSI GTX 680 Lightning, Corsair AX760i ,Case Fans : Front : CM 200 blue,Rear : Corsair AF 120 PE , Klipsch 2.1 , Sennheiser HD650 , 2 x Samsung 23" 1080p , Logitech G710+
Tags
build, gold, itx, prodigy, watercooling
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
