Thread Tools Display Modes
  #131
Old 04-02-13, 01:54 PM
NeverBackDown NeverBackDown is online now
AMD Enthusiast
Well just laugh and say your just jealous i'm already faster
  #132
Old 04-02-13, 05:26 PM
USAdystopia USAdystopia is offline
Newbie
Get a Swiftech H220, Kraken 60 or Corsair for that nuclear powered 3770k.
6 months from now that 7950 is going to be sitting much lower in the GPU hierarchy!
  #133
Old 05-02-13, 12:07 AM
AMD Enthusiast
Thats why you buy another one or OC
H220 outperforms all those coolers mentioned for like 15$ more and can be tunred into a custom loop which right there makes it more worthwhile
  #134
Old 05-02-13, 09:00 AM
Destro521 Destro521 is offline
Member
kk just hope my stryker can cool 2 7950s haha but i will be buying more fans as i earn more money
and the h220 is on my shopping list ;D
__________________
Z77 Asrock Oc Formula, I7 [email protected] 4.2GHz (haven't fine tuned yet), XFX XXX 850w, CM Storm stryker, Dual XFX 7950 black editions @ 1200 core and 1575 memory
  #135
Old 05-02-13, 01:57 PM
AMD Enthusiast
Your striker can but will do better with good fans. Glad to hear about the h220!!
  #136
Old 12-02-13, 10:46 PM
Member
Hey guys I just wanted to say thank you to everyone that helped me along the way I don't know if I got lucky or not by my crossfired 7950s both reached 1200 core and 1575 Memory and I still have quite a bit of headroom on both cards.
Im going to need to get 2 fans just so I can get the load temps down in the summer months as here my room sits at 40 celcius and my cards at 41-42.
When I took the case out of the box I didn't expect the sheer size it had ;p
I haven't Oced my CPU yet but I will look into it today
__________________
  #137
Old 12-02-13, 11:11 PM
AMD Enthusiast
Glad to hear it went well! I would not bother OC'ing memory on gpus.. not much benefit. Focus on all core clock then go ahead and get your memory higher
  #138
Old 13-02-13, 07:31 AM
Deejeta Deejeta is offline
Advanced Member
Good work champ. Looks like you won the silicon lottery twice with those clocks on both cards.
Yeah maybe wait for this awful heatwave to bugger off before heavy o'cing the ivy chip. My water temp got to 45c today under load, with the room at 38c.
__________________
"Western civilization is a loaded gun pointed at the head of this planet." McKenna
  #139
Old 13-02-13, 10:34 AM
Member
once i get a job i can then purchase a h220 but currently using a hyper 212 as i received a call from PLE saying the i30 freezer would not fit on the mobo.
my load temps are anywhere between 65-85 but my top gpu is doing more of the work than the bottom. is there any way to fix that?
I managed to artifact today with a high 101 degrees as my room shot up to 48 room temp. surprisingly it was because i turned SSAO on in wargame European escalation. while the game was running at 175+ FPS the temps still got the better of the fans D: i have also heard of turning off the ULPS but i don't know what it deos.
i didnt have time to OC the cpu as i had to sort out a bunch of travel-related stuff to get to my tafe in thornlie
__________________
  #140
Old 13-02-13, 11:25 AM
Lystfiskern Lystfiskern is offline
OC3D Crew
Youre age and income-situation in mind I would be very careful pushing your system to hard before u have a better cooling solution mounted.
A severely high ambient temp will effect your running temps a lot. If u got temps
in the 40s C in your room U should get on to as large of a wc-system as u can - as fast as u can. Til then - keep your system as cool as u can and enjoy the thing.
__________________
[SIZE="2"][FONT="Book Antiqua"]Fractal Design Define R5W White / Corsair AX760i[/ EVGA Z97 FTW / Intel® Core i7-4790K / 32GB Kingston HyperX Savage 2400Mhz / Samsung 850 Pro 250Gb/Corsair Force Series GT 240Gb / HGST 4Tb / Seagate Barracuda 3Tb / MSI GTX970 Gaming / Corsair H100GTX - Corsair SP120QE / Dell Ultrasharp U2410/ Corsair AF140QEx2 Front / Corsair AF120QEx2 Bottom/Back
Tags
crossfire, sli, storm stryker, z77
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
