Thread Tools Display Modes
  #11
Old 25-07-12, 09:04 PM
Ashton187 Ashton187 is offline
Newbie
Originally Posted by jamesriley94 View Post
....Why still the 680?
Well i want the best and i want it to last 2 years. Getting the 670 when the 680 is there doesn't seem like getting the best.
http://www.anandtech.com/bench/Product/598?vs=555
Shows that the 680 beats it, while performance is comparable, its still not as good as.
  #12
Old 25-07-12, 09:05 PM
jamesriley94 jamesriley94 is offline
OC3D Elite
How many monitors are you using?
  #13
Old 25-07-12, 09:06 PM
seumasbeathan seumasbeathan is offline
Banned
but also as cheap as possible. If i don't need it, i don't want it,
Taken from the op, you do not need a 680 and getting one is just wasting money, don't ask for advice if you are just going to ignore it
  #14
Old 25-07-12, 09:14 PM
yassarikhan786's Avatar
yassarikhan786 yassarikhan786 is offline
OC3D Elite
Dude, the performance difference between the 670 and 680 is not massive my any means. The 670 is a smart purchase.
__________________
Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: EVGA GTX 780 Ti ACX || Memory: 16GB - Mushkin Blackline 8GB + Corsair Vengeance LP 8GB || SSD's + HDD's: Samsung 850 EVO 500GB (OS + Programs) + Caviar Black 2TB (Games + Storage) || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v
  #15
Old 25-07-12, 09:23 PM
Newbie
1x 24" LED Benq 1920x1080
And i have a 19" connected but i never game over the 2, just on the 1 listed above.
  #16
Old 25-07-12, 09:24 PM
Newbie
What about if i swapped to a 3gb 7970?
  #17
Old 25-07-12, 09:25 PM
Banned
Take our advice and go with the 670, you won't be dissapointed
  #18
Old 25-07-12, 09:27 PM
OC3D Elite
Yeh, look back at the benchmarks - on 1 screen at 1080p, the 670 gets pretty much over 60fps on every game, so there wont be any difference between the 670 and the 680. The only games that dont are the games that are coded poorly in the first place and so will always be a bitch with FPS.
  #19
Old 25-07-12, 09:30 PM
Newbie
I really want to trust your opinions and its the reason i'm here. But in the back of my mind i have this burning sensation saying to ignore you and take the 680!
I know your right, but i can't help but feeling in the long run I'd be always regretting i didn't get the 680.
Thing is the 680 4gb comes in under my budget with the spec i listed, so technically i could afford it, its just a case of is it the right choice.
  #20
Old 25-07-12, 09:32 PM
OC3D Elite
No, listen to us, because we're amazing.
Also, look at the clock speeds of the 670 and 680. If you overclock the 670 to the same clock speed as the 680, it actually performs better, so just overclock it, and you have better performance
/end
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
