View Poll Results: Have I Created a Good Build I can Expand off of in the Future?
Good Build Base 10 62.50%
Needs More Thought 5 31.25%
Completely Useless 1 6.25%
Voters: 16. You may not vote on this poll
Thread Tools Display Modes
  #51
Old 29-04-12, 10:50 PM
SPS SPS is offline
Moderator
Just a thought: Get a 3770 over a 3770K if you're not going to overclock?
__________________
  #52
Old 29-04-12, 10:58 PM
GamerGirlAlice GamerGirlAlice is offline
Member
Send a message via MSN to GamerGirlAlice Send a message via Yahoo to GamerGirlAlice
ASUS P8Z77-V Deluxe Build
ASUS P8Z77-V DELUXE LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i7-3770K Ivy Bridge 3.5GHz (3.9GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I73770K
CORSAIR H100 (CWCH100) Extreme Performance Liquid CPU Cooler
CORSAIR Vengeance 8GB (2 x 4G 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9B
Corsair Force Series 3 CSSD-F120GB3A-BK 2.5" 120GB SATA III Internal Solid State Drive (SSD) x2
Corsair Force Series 3 CSSD-F60GB3A-BK 2.5" 60GB SATA III Internal Solid State Drive (SSD)
HITACHI 4TB SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive x2
HITACHI 2TB SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
LG Black 12X Super Multi Blue with 3D Playback & M-DISC Support SATA WH12LS39 LightScribe Support
CORSAIR Professional Series Gold AX850 (CMPSU-850AX) 850W ATX12V v2.31 / EPS12V v2.92 80 PLUS GOLD Certified Full Modular Active PFC Power Supply
BYTECC Bracket-35225 2.5 Inch HDD/SSD Mounting Kit For 3.5" Drive Bay or Enclosure
Corsair Vengeance K90 Black/Metal USB Wired Gaming Performance, MMO Mechanical Keyboard
Corsair Vengeance M90 Black 15 Buttons 1 x Wheel USB Wired Laser Performance, MMO/RTS Gaming Mouse
Corsair Gaming Audio Series SP2500 High-power 2.1 PC Speaker System
Hauppauge HD PVR Gaming Edition
NVIDIA NVIDIA 3D Vision 2 Wireless Glasses Kit
__________________
  #53
Member
ASUS ROG Maximus V Gene Build
ASUS Maximus V Gene LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
CORSAIR Vengeance 8GB (2 x 4G 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9R
Corsair Force Series GT CSSD-F120GBGT-BK 2.5" 120GB SATA III Internal Solid State Drive (SSD) x2
CORSAIR Professional Series Gold AX650 650W ATX12V v2.31 / EPSV12 v2.92 80 PLUS GOLD Certified Full Modular Active PFC High Performance Power Supply
__________________
  #54
Old 29-04-12, 11:20 PM
Member
i am overclocking but plan to use the asus software to do, i don't think i would myself. the asus software scans the computer config and oc the best it can for the system build. that's why i am getting the k series.
__________________
  #55
Old 29-04-12, 11:27 PM
S_I_N's Avatar
S_I_N S_I_N is offline
OC3D Elite
ok I have looked and looked but cant find anything saying the IRST is supported on the third party chips, found plenty that says its on the Z77 chip which is what it was designed to work on. After all it is an Intel thing and it makes perfect sense that its only supported on Intel chipsets.
Now looking at your 2 wish lists I do still like the first one better as its an ATX board and I'm partial to them. I did not that in neither list did you have a gpu listed. Yet you had Nvidia 3D glasses. Next you memory choice if I was building planning on using all 4 dimms then i would grab a quad kit. When these kits are put together they hand pick which parts go into each kit to make sure they work well with each other. I havent priced mem in awhile now but I'd look at a 2x8GB kit and stay with a single dual channel kit other wise i'd pick a quad if you think 4 dimms are better than 2. I run 2x4GB Snipers and have never ran into a memory issue but I dont do dugital media editing.
so my rec's is drop the 60GB cache drive for storage and change mem kits to either 2x8GB or 4x4GB and find a gpu
__________________
Intel 7700K
Aorus Z270 Gaming K7
2x8GB GSKILL Trident Z 3200MHz
Intel SSD6 256Gb x2 in Raid 0
Samsung 850 EVO 1TB
EVGA GTX1080 FTW2 iCX Heat Killer IV block
Custom water Cooled Hardware Labs GTS360/240
ThermalTake Grand RGB 1000w PSU
Corsair Crystal 570X
  #56
Old 29-04-12, 11:56 PM
Member
gpus i haven't deiced on yet, if i do rog ill get a rog 600 series and rog xonar card when released. the deluxe build id do sli on hence psu difference.. currently i have a 280 and a samsung 22" 3d monitor. my 3d kit is messed up that's why the 3d v2 kit is in there.
__________________
  #57
Old 30-04-12, 12:37 AM
S_I_N's Avatar
OC3D Elite
how much do ya do in 3D??? I have a 27inch sammy 3d monitor and while 3D is cool i find myself enjoying it more for the 120Hz refresh rate more than 3D.
__________________
Intel 7700K
Samsung 850 EVO 1TB
  #58
Old 30-04-12, 12:53 AM
Member
i watch 3d movies and play a little bit of wow in 3d, but v1 glasses are uncomfortable for me because i wear glasses. but movies in 3d sweet.
__________________
  #59
Old 30-04-12, 02:37 AM
S_I_N's Avatar
OC3D Elite
hmm I havent tried 3D movies on my 27incher yet might look into it. But I'd rather watch my 65 inch tv vs a 27inch monitor lol But I agree 3D glasses and normal glass = PITA
__________________
Intel 7700K
Samsung 850 EVO 1TB
  #60
Old 30-04-12, 03:50 AM
Member
my regulatr tv isnt 3d but when it fails geting one
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
