View Poll Results: Have I Created a Good Build I can Expand off of in the Future?
Good Build Base 10 62.50%
Needs More Thought 5 31.25%
Completely Useless 1 6.25%
Voters: 16. You may not vote on this poll
Thread Tools Display Modes
  #11
Old 28-04-12, 05:20 PM
GamerGirlAlice GamerGirlAlice is offline
Member
Send a message via MSN to GamerGirlAlice Send a message via Yahoo to GamerGirlAlice
yeah it comes down to im building a gaming and digital media creation macine with longgevity of future proof items. im chnging the build slitl 2 dual corsair force series 120gb ssd boot, 4 hitach 4tb storage drives, 8gb dual kit (CMZ8GX3M2A1600C9G)
__________________
  #12
Old 28-04-12, 05:27 PM
Jadarite's Avatar
Jadarite Jadarite is offline
OC3D Crew
Send a message via MSN to Jadarite
I think your going to have an awesome rig there, the only thing i'm not keen on is the case but thats just me i'd go for the 600T instead
__________________
"The answer to life the universe and everything is 42 "
Power Supply Calculator Guide (you might have to F5 this)
  #13
Old 28-04-12, 05:29 PM
S_I_N's Avatar
S_I_N S_I_N is offline
OC3D Elite
you may need to 16Gb for your digital media I'd got 2x8gb if ya think you'll use it all. with current overclocking limits (multi only) issues of the past with all dimms populated I dont see any hinderance with 4x4gb either. But I havent tried it so i cant comment fully.
__________________
Intel 7700K
Aorus Z270 Gaming K7
2x8GB GSKILL Trident Z 3200MHz
Intel SSD6 256Gb x2 in Raid 0
Samsung 850 EVO 1TB
EVGA GTX1080 FTW2 iCX Heat Killer IV block
Custom water Cooled Hardware Labs GTS360/240
ThermalTake Grand RGB 1000w PSU
Corsair Crystal 570X
  #14
Old 28-04-12, 05:45 PM
Member
working on a updated complete list
__________________
  #15
Old 28-04-12, 05:53 PM
xdaax xdaax is offline
Newbie
If you raid them, too. I would recommend either raid 10,6 or 5. 10 would give you 8TB of usable disk space and about double read and write rates(one drive can fail with out loosing data). 6 would give you 8 TB as well, the read rates are better too but on write rates there isn't that much performance increase(6 allows 2 drive failures without loosing data). 5 would give you similar to 6 not that much performance increase in write rates and a decent raise in read rates, but would give you 12TB accesable space(5 drive can fail with out loosing data ) The performance increase in write rates is heavyly effected by the controller.
Conclusion :
raid 10: high write rates
raid 6: data safety
raid 5: much usable Space
__________________
  #16
Old 28-04-12, 06:01 PM
Member
the reason i chose the case is i am a corsair fan girl, all steel including front panel, internal usb 3.0 header, green goes well with sabertooth, and handles if i deiced to go to a lan party from a group i belong too.
updated complete build list ready:
  • Ivy Bridge i7 3770K CPU
  • ASUS SABERTOOTH Z77 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
  • ASUS GeForce GTX 680 DirectCU II TOP
  • Corsair Link Cooling and Lighting Kit
  • Corsair Force Series™ 3 120GB SATA 3 6Gb/s Solid-State Hard Drive
  • Corsair Gaming Audio Series™ SP2500 High-power 2.1 PC Speaker System
  • Corsair Hydro Series™ H100 Extreme Performance Liquid CPU Cooler
  • Corsair Professional Series™ Gold AX1200 — 80 PLUS® Gold Certified Fully-Modular Power Supply
  • Corsair Professional Series™ Gold AX1200 Individually Sleeved Modular Cables — Black
  • Corsair Vengeance® — 8GB Dual Channel DDR3 Memory Kit (CMZ8GX3M2A1600C9G)
  • Corsair Vengeance® 2000 Wireless 7.1 Gaming Headset
  • Corsair Vengeance® C70 Mid-Tower Gaming Case — Military Green
  • Corsair Vengeance® K90 Performance MMO Mechanical Gaming Keyboard
  • Corsair Vengeance® M90 Performance MMO and RTS Laser Gaming Mouse
  • LG Black 12X Super Multi Blue with 3D Playback & M-DISC Support SATA WH12LS39 LightScribe Support - OEM
  • HITACHI H3IK40003254SW 4TB 5400 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
  • NVIDIA NVIDIA 3D Vision 2 Wireless Glasses Kit
  • Hauppauge HD PVR Gaming Edition
  • BYTECC Bracket-35225 2.5 Inch HDD/SSD Mounting Kit For 3.5" Drive Bay or Enclosure
__________________
  #17
Old 28-04-12, 06:06 PM
Ibanez81 Ibanez81 is offline
Advanced Member
The Sabertooth is only Dual channel RAM i think?
The AX series all come with enough cables to power 2 GPU's
Personally for a build like that id get a full tower for room.
EDIT: was typing this before you posted that lol
__________________
[CASE] NZXT Switch 810 Modded
[MB] Asus Sabertooth z77
[CPU] i5 2500k @ 4.8ghz 1.4v
[GPU] XFX Black Edition 7970 @ 1125/1575
[PSU] Corsair AX750
[STORAGE] Corsair Force 3 120GB, 2x 500GB HDD
[COOLING] D5 vario/ 360mm RAD / 240mm Rad/ 150mm Tube Res / Raystorm / EK GPU Block
[PROJECT LOG] http://forum.overclo...ject-something/
  #18
PetrolHead247's Avatar
PetrolHead247 PetrolHead247 is offline
OC3D Crew
Looks awesome. Defo consider 16GB of RAM seeing as you've said you're going to be doing media stuff, but you may get away with 8GB, it just all depends on what exactly the rig is going to be used for. As for the case, defo buy it, the military green C70 will look absolutely insane with the Sabertooth board!
__________________
My Rig - Vanquish (Pics Here!)
CPU: Intel Core I5 2500K :: Mobo: Asus P8P67 :: GPU: Asus GTX 670 DCUii :: RAM: Corsair Vengeance LP White 2x4GB 1.35v :: CPU Cooler: Corsair H100 w/Corsair SP120 QE's
SSD: Samsung 830 256GB :: HDD: Seagate Barracuda 500GB 7200.12 :: PSU: Corsair AX650 w/ Individually Braided Cables :: Case: Fractal Design Arc Midi :: Monitor: Asus VS228H
  #19
Old 28-04-12, 06:16 PM
Member
the z77 is a dual channel. but asus has been verified ocing all dims populated. the quad channel kit was a attempt to match all the ram but being dual channel i could probably just use dual 8gb kits
__________________
  #20
Old 28-04-12, 06:20 PM
Zaim Zaim is offline
Member
I'd change the SSD to a ForceGT, only cost a little more but they are faster and well worth the extra. Other than that you have a very nice build there.
__________________
CPU:Intel I7 3770K|CPU Cooler:Noctua NH-D14|RAM:16GB Corsair Vengeance White LP |MB:ASUS P8Z68-V Pro/Gen3|GPU:Asus GTX 980 Strix|PSU: Corsair AX750|Hard Drives: 2xCorsair Force GS 240GB SSD, WD 2x2TB|OS: Windows 8.1|Sound Card: Xonar HDAV|Speakers:Speakers:Sony STR-DN850+Yamaha Speakers+Tannoy TS2.10|Corsair K95 Corsair M95|
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
