Thread Tools Display Modes
  #61
Old 27-12-11, 11:33 AM
arvindsond arvindsond is offline
Newbie
Superb, thanks for that. The SSD seems to betting decent enough reviews, so I guess it cant be that bad
Arvind
  #62
Old 27-12-11, 11:36 AM
yassarikhan786's Avatar
yassarikhan786 yassarikhan786 is offline
OC3D Elite
Arvind
Yep, if it's getting good reviews, then by all means go for it
__________________
Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: EVGA GTX 780 Ti ACX || Memory: 16GB - Mushkin Blackline 8GB + Corsair Vengeance LP 8GB || SSD's + HDD's: Samsung 850 EVO 500GB (OS + Programs) + Caviar Black 2TB (Games + Storage) || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v
  #63
Old 06-01-12, 01:08 PM
Newbie
Hi guys, Happy New Year...... well all the parts have arrived and they've been installed, it looks like a beast, currently installing windows. Back at work at the moment, so when I get back home gonna update bios and then continue with all software installations.
Had a moment of worry when I first turned on the machine and there was nothing coming up on the monitor, didn't know whether it was an issue with GPU, CPU, Mobo, or RAM or all four..... then I realized that the main case fan wasn't rotating, plugged it into another fan slot on the mobo, it started spinning and the PC posted into the bios....crazy!!!
I'll report back when it's properly up and running.
Arvind!
  #64
Old 06-01-12, 01:29 PM
OC3D Elite
Arvind!
Awesome. Show us some photos of your new system as well if you can.
__________________
  #65
Old 12-01-12, 07:51 PM
Newbie
Hi guys, ok so everything is up and running smoothly, all my 3D software works amazingly fast and windows boot times are quick.
I do have a question though, I started to mess round in the bios with overclocking and I followed an in depth tutorial to overclock to 4.5ghz, but for some reason on both cpu-z and the sensor on AIsuite the cpu speed comes in at 1200MHz which is fine for idle, but I used prime95 to stress test it, and all 12 cores didn't budge from 1200MHz
Am I doing something wrong here?
Any help is appreciated fellas
Thanks
Arvind!
  #66
Old 13-01-12, 12:59 PM
Newbie
Actually sorted it guys, had to set the overclocker tuner to XMP setting, which has got me to 3.5ghz, so will have to try and push to 4ghz
Arvind!
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
