Thread Tools Display Modes
  #21
Old 08-12-11, 09:46 PM
SPS SPS is offline
Moderator
I was just curious because it sounds like a monstrous build!
And that Dell monitor wow
As far as mobos go, don't get an 'ultimate' one because you will probably find you wouldn't know the difference between a 'good' board after a while
__________________
  #22
Old 09-12-11, 09:19 AM
arvindsond arvindsond is offline
Newbie
Thanks guys, your being extremely helpful, much appreciated.
I was looking for one of those 'closed loop' water coolers which manage themselves, I thought the corsair Hydro H80 might do it, the reviews didn't seem bad.
Hows the Noctua-D14 taz838? Ill check the reviews, do you know if there noisy?
I'll look into the other makes you mentioned
Thanks again
Arvind!
  #23
Old 09-12-11, 11:16 AM
Newbie
Hey guys, is it just me, because when I check the reviews and test results of the above cpu coolers, the Corsair H80 O mentioned seems to be getting really good temp results compared to the others like thermaltake, antec, silver arrow (which doesn't seem to have a lga2011 cpu cooler yet), nzxt havik, or the nh-d14. Although the NH-D14 did get good results aswell.
Any suggestions
Thanks
Arvind!
  #24
Old 09-12-11, 11:19 AM
yassarikhan786's Avatar
yassarikhan786 yassarikhan786 is offline
OC3D Elite
Any suggestions
Thanks
Arvind!
It's up to you mate, but the stock fan(s) on the H80 will be louder than the D-14.
__________________
Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: EVGA GTX 780 Ti ACX || Memory: 16GB - Mushkin Blackline 8GB + Corsair Vengeance LP 8GB || SSD's + HDD's: Samsung 850 EVO 500GB (OS + Programs) + Caviar Black 2TB (Games + Storage) || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v
  #25
Old 09-12-11, 11:44 AM
Newbie
Ah ok, that's good to know. There wasn't much difference between the two in terms of temp, so the NH-D14 sounds like a winner to me then!
http://www.scan.co.uk/products/noctu...oogle+shopping
Thanks
Arvind!
  #26
Old 09-12-11, 11:53 AM
OC3D Elite
Thanks
Arvind!
Good Choice
__________________
  #27
Old 09-12-11, 02:57 PM
taz838 taz838 is offline
Newbie
Originally Posted by yassarikhan786 View Post
Good Choice
You mean great choice!
  #28
Old 09-12-11, 03:06 PM
OC3D Elite
Yeh, that .
__________________
  #29
Old 09-12-11, 03:07 PM
SPS SPS is offline
Moderator
The NH-D14 is silent with excellent temps.
__________________
  #30
Old 09-12-11, 03:21 PM
Newbie
Awesome, cheers fellas, OK next question
My budget stretches to one gtx 580 and I was looking for one with 3GB of onboard RAM cos it really helps when working with heavy 3D scenes with lots of textures (which I will be) do you guys have any preference, I've read individual reviews but not sure which is best overall.
The Gainward seems like the best to me, any comments on this:
http://www.overclockers.co.uk/showpr...14&subcat=1812
oh, and Happy Friday!
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
