Go Back   OC3D Forums > [OC3D] General Forums > OC3D Reviews & Videos
Thread Tools Display Modes
  #31
Old 09-11-11, 05:34 PM
Timbaloo Timbaloo is offline
Member
I'd rather use the internal graphics for an office pc.
  #32
Old 09-11-11, 09:55 PM
ionicle ionicle is offline
OC3D Elite
Originally Posted by sheroo View Post
If you have a side window, your PC will look like a washing machine.
i likes
just fill the rest of the pc with watercooling (gpu, ram, chipsets etc) and it will complete the look
__________________
  #33
Old 11-11-11, 08:48 PM
JPEGONE JPEGONE is offline
Newbie
hey guys, i think the graph is a little messed up. It says the average is higher than both the Delta AND the Idle. I think the Delta temp needs to be switched with average. Just throwin that out there for ya
  #34
Old 12-11-11, 08:05 AM
Vorpal Vorpal is offline
Newbie
The heck you say... the temperature is never colder than ambient for air cooling, so Average > Ambient. Delta = Average - Ambient by definition, so yes, numerically Average should be greater if Ambient is positive. Don't know what graph you're looking at to get 'Idle', but the one in the main review looks perfectly consistent.
But it makes no sense to compare Delta to either Average or Ambient anyway, because the latter are actual temperatures while Delta is a relative difference. If for some reason TTL wanted to use kelvin (or gods forbid, rankine) scale, the first entry might have looked like:
Delta: 57.25, Avg: 351.40, Ambient: 294.15
And still it's the Delta that's directly indicative of the cooling ability of the heatsink.
  #35
Old 15-11-11, 08:04 AM
Stryker64 Stryker64 is offline
OC3D Elite
Imagine what temps you'll get if you had it in the Silverstone FT02 case .
  #36
Old 18-12-12, 02:53 PM
totesmagotes totesmagotes is offline
Newbie
I use my computer for gaming, media, and work, and I can't stand PC noise (especially when I'm using it for work), so I'm strongly consider getting this because my CPU is where the majority of my PC's noise is coming from. I am concerned about the cost however, and also the fact that I'd have to remove it just to replace my RAM, and for all I know, I might take it out of the box and find that it doesn't fit.
  #37
Old 11-12-13, 10:28 AM
loty1825 loty1825 is offline
Newbie
Were those tests made with side cover open or closed?
  #38
Old 11-12-13, 10:38 AM
tinytomlogan's Avatar
The Guvnor
Closed
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
