Thread Tools Display Modes
  #11
Old 08-07-10, 11:50 AM
AMDFTW AMDFTW is offline
OC3D Elite
ha ha yer that was luck fella
citylink FTW
  #12
Old 08-07-10, 12:10 PM
thestepster's Avatar
thestepster thestepster is offline
OC3D Elite
yeah and im back now from having to nip out so i was only out like 15 mins but that was enuff to have missed him gonna get on with this build soon just having a peep at that noctua holy **** huge isnt the word!!
__________________
Intel Core i7 @ 4ghz and rising!
Noctua NH-D14 - Samsung F3 1TB - Asus P6X58D Premium - 12GB Corsair XMS3 1600
Zotac GTX580 at 895/1790/4200 @ 1030v (1000mv stock @ 772 core) - Corsair TX850 - Corsair 700D
  #13
Old 08-07-10, 12:35 PM
tinytomlogan's Avatar
The Guvnor
what ram you got going with that fella?
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #14
Old 08-07-10, 12:38 PM
OC3D Elite
yer i dont think that noctua beast will fit on my board
  #15
Old 08-07-10, 12:39 PM
The Guvnor
It wont with the std dom coolers matey.
__________________
  #16
Old 08-07-10, 12:41 PM
OC3D Elite
booo its a shame DAM them heatsinks being so high
good look with the build fella,i hope you see a inprovment performance wise
  #17
Old 08-07-10, 12:43 PM
I Hunta x's Avatar
I Hunta x I Hunta x is offline
OC3D Elite
He has the standard 1600 XMS3 if i remember rightly tom.
Dont the doms fit if you un screw the little fin bits on top (iirc you can remove JUST them with like 2 screws)
__________________
i7 970 @ 4.2Ghz - NH-D14 | Gigabyte x58a-oc | Corsair AX850 | CM Cosmos S
4x4Gb Samsung Green in 3+1 Tri Channel - 1900Mhz c10 1.3v | R9 290 | Samsung 840 Evo
Beyerdynamic Custom One Pro + V-Moda Boompro
-Need to fit-
Xspc Rasa | Phobya G-Changer 240 + 360 | Phobya dc12-400 | 7x Orange Xigmatek XLF 120mm
| Alphacool Copper fittings
  #18
Old 08-07-10, 12:46 PM
OC3D Elite
corsair xms3 1600
http://corsair.pricegrabber.com/sear...utmk=170807328
ill definately see a massive improvement mate i get about 6k on my q6600 while folding!
__________________
  #19
Old 08-07-10, 12:48 PM
OC3D Elite
isnt that the dominator gt's u can do that with?
__________________
  #20
Old 08-07-10, 12:52 PM
The Guvnor
The Dom GT's can be removed. AMDFTW has the old DDR2 versions that are fixed.
Steppy's are fine though.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
