Thread Tools Display Modes
  #61
Old 10-05-10, 04:48 PM
tinytomlogan's Avatar
The Guvnor
aye res must always come before the pump.
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #62
Old 10-05-10, 09:57 PM
siravarice's Avatar
siravarice siravarice is offline
OC3D Elite
Ok cheers Tom, I will get creative with the tubing and what not. Also, I won't be getting a UD5, it will be the UD3R, they just didnt have any in stock and i didnt like the look of the one thing on the side :P
__________________
AMD Phenom II x4 970*
16GB RAM*
GTX 460*
*Won at a Xmas party raffle.
  #63
Old 11-05-10, 10:24 AM
siravarice's Avatar
OC3D Elite
I've changed the 5870 for a GTX480. I figured the performance would be better on the 480, and in games the Phys X wouldn't have to be pawned off to the CPU to compute. And it's only £10 more than the 5870 I was going to get. So overall a better choice I think.
__________________
16GB RAM*
GTX 460*
  #64
Old 11-05-10, 11:08 AM
AMDFTW AMDFTW is offline
OC3D Elite
yer the gtx 480 will be better IMO but some might say different,and of course you can go SLI eventualy and thats just insane,just be aware of the heat them things produce and also the noise,i no you said u wanted a quite pc i dont think you will get it with a 480 on 80% fan speed.
  #65
Old 11-05-10, 11:28 AM
The Guvnor
A 480 is never going to be called quiet, even with Auto fans it hits 90% fans and 100c.
Quiet it is not.
__________________
  #66
Old 11-05-10, 02:44 PM
OC3D Elite
how loud is it respectivly i have a 9800gtx sitting at 100% fan 24/7 and it dont bother me much i also had my gtx 260 at 100% is it louder on on par with any of them
  #67
Old 11-05-10, 03:10 PM
The Guvnor
The 260 was a quiet card. its at least twice as loud as those two matey. When I say loud I mean it. That and the fact Sira said silent/quiet and thats never going to be a 480 unless its watercooled. I wouldnt even recomend a reference ATI cooler for quiet tbh.
__________________
  #68
Old 11-05-10, 04:04 PM
OC3D Elite
oryt so you would say 4890 at 100% fan speed,that was just awful
  #69
Old 11-05-10, 11:07 PM
siravarice's Avatar
OC3D Elite
It will be watercooled so I'm not worried about that.
__________________
16GB RAM*
GTX 460*
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
