Thread Tools Display Modes
  #21
Old 30-11-07, 08:08 PM
JN JN is offline
OC3D Elite
Originally Posted by name='hawkinsa21'
Its the core speed that is low, isn't it supposed to be showing something like 2400Mhz??
I have disabled EIST, C1E, and the Thermal thingy as well...
One word.....Vista.
I spent AAAAAAGES trying to work out why my CPU speed was fluctuating like C1E was enabled, and eventually I found out loads of other people were complaining about it too. Vista seems to ignore/override the C1E setting on some motherboards. In this case it was an Abit..not sure about other boards.
  #22
Old 30-11-07, 08:25 PM
hawkinsa21 hawkinsa21 is offline
Member
Originally Posted by name='XMS'
One word.....Vista.
Thanks XMS, thats a relief that I'm not going mad. lol
So, I guess my next question is that am I meant to be seeing 2.4Ghz in the core speed??? Here it just looks to me like 1.24Ghz
EDIT: PS just ran SuperPi, and got 45sec @ 1M..... something looks wrong there
I'm gonna reset CMOS and start over
  #23
Old 30-11-07, 08:34 PM
JN JN is offline
OC3D Elite
You will probably only see it jump to 2.4 when the processor is not idle. Try Prime95 or SPI to see if it bumps back up.
...And ye 45sec is pretty shoddy for ur setup
  #24
Old 30-11-07, 08:51 PM
FarFarAway FarFarAway is offline
Newbie
45 seconds is appalling
Make sure you've disabled:
Speedstep
C1E
Thermal Throttling.
Vista is NOT the issue here, I have an IP35 Pro running Vista Ultimate and have no issues like that
If you need me to come take a look gimme a shout Al
  #25
Old 30-11-07, 09:04 PM
Member
Thanks bud, I'm taking a further look in the BIOS now. Couldn't see Speedstep though??
  #26
Old 30-11-07, 09:12 PM
ken_shiro ken_shiro is offline
Newbie
I have Vista and an overclocked Q6600 and haven't had this problem since i disabled speedstep
  #27
Old 30-11-07, 09:48 PM
Newbie
OK so here's what I have (remember I'm using a golden Xeon that gets 3.3Ghz @ 1.275v)
Failing copying that I dunno what other BIOS settings you would do
Actually just noticed my RAM isn't at 1100MHz...must sort that out
  #28
Old 30-11-07, 10:19 PM
Member
Thanks Kempy, checked it all and its all good. Same as you bud...
Please stare in amazement at my new and improved 3DMark06 score, it rocks... remember, Q6600, 2gb Corsair Dominator, 8800gt, Abit IP-35
I just don't know what to do... should I start looking at RMA'ing any of the parts??
I will reset the CMOS again and do a test from scratch, ALL defaults.
Off to bed now though, might dream of an AMD XP 2200 thrashing my quaddy in SuperPi... thats a nightmare I know, but more likely a reality for me at present...
  #29
Old 30-11-07, 10:26 PM
Pyr0 Pyr0 is offline
OC3D Crew
theres deffo something wrong there somewhere
are you certain that your "External Clock" option in the BIOS is set correctly ?
usually if it's a speedstep problem, the multiplier drops and the bus speed stays the same *shrug*
with those settings above, you are running with FSB and MEM at half speed and with seriously reduced bandwidth
__________________
Intel i7 950
Gigabyte EX58A-UD3R
3x4GB GSkill Ripjaws PC3-12800
AMD HD 6970 2GB & Dell 3007WFP-HC
Asus Xonar DX
Crucial C300, Vertex1, Velociraptor & Sammy F3's
Corsair AX850
Windows 7 Ultimate x64 SP1
  #30
Old 30-11-07, 11:02 PM
Member
Hey Pyr0, thanks for your reply.
The external clock is set to 277Mhz, x 9 should be around 2493Mhz... so that looks fine.
I have reset the CMOS many times now, and tried all sorts of configs. The last reset the only thing I changed was turning off the thermal features, C1E and EIST... still get totally rubbish core speed... I just don't know... I have even tried JUST default BIOS, as I did get 9027 3DMark06 points at first, but its all gone downhill since then. Its definately the CPU thats showing as being rubbish, but could the memory affect this??
Can anyone suggest what things to try? Should I try the memory in the other memory slots?? They are dual channel in the two blue slots, so I could try the blacks... ??
Is it worth reseating the proccy?? I can't see that that would matter though as its stable and temps are low
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
