Thread Tools Display Modes
  #61
Old 21-05-04, 11:48 AM
mcmad mcmad is offline
Advanced Member
Originally Posted by gorby
MCmad you don’t necessarily need one of these. As long as your printer has a NIC inside then u can just hardwire it to your router or access point...
Im obviously not hitting the right notes with you standin but here goes anyway
As long as the access points are all in the same IP scheme and have the same security settings then you will be fine...
Get one computer hard wired into the new access point and ensure that these settings are the same as on your router:
Security system ( open, shared or not at all)
Wireless session identifier (or wireless network name)
frequency operating range
Wireless transmit speed and or protocol ( 802.11b etc)
heres the most crucial scratched record bit ....
In the same IP range as the routter and clients...
ie: if original router was 192.168.0.1
clinet dhcp range = 192.168.*.*
new access point must be within the dhcp range!!!!!!
yup, Ive got my main laser printer hooked up with its own NIC, the injet is on a print server.
  #62
Old 21-05-04, 12:38 PM
gorby gorby is offline
Member
yer thats the one, Ive just seen a lot of people buy them needlessly when they could have just wired them into an access point, a wired printer then becomes wireless.
Perhaps i could rap that up in some pr and then sell it
__________________
<ahref="http:>Amd Xp 1800 clocked @ 1725
msi microatx board with some via controller
1 GB 3200
1TB array
2 x Hauppauge WinTV PVR-250
:OnVidia Corporation NV11 [GeForce2 MX/MX 400]:O
Linux 2.6.8-2-k7
nvidia module 1.0-8178
xorg
mythv
apache2
</ahref="http:> [EP-UK] Uptime Stats]<ahref="http:></ahref="http:>
  #63
Old 21-05-04, 12:52 PM
standin wave standin wave is offline
OC3D Crew
Dazed n Confuzed
Gorby/Mcmad, will give it a go, but I'm still unclear whether the WAP54G CAN be just wireLESS or not and what this 'repeat' mode is?? btw I not have suitable conn on my printer, its USB or parallel. When all my PCs were close enough, they all worked fine printing to it, wirelessly
sw
__________________
Where's that blinkin dynasig link when u need it?
  #64
Old 21-05-04, 01:17 PM
Advanced Member
run the setup disk m8, it will be fine.
  #65
Old 21-05-04, 01:19 PM
Member
yes m8 it can work completely independently without getting lonely and needing a wire up its butt
__________________
1 GB 3200
1TB array
Linux 2.6.8-2-k7
xorg
mythv
apache2
  #66
Old 21-05-04, 01:24 PM
OC3D Crew
wire up my butt, now thats something to try this weekend! I won't blame you when I fry my gpu though
u can tell its friday, I can sense BBQ and beer approaching ...
sw
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
