Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
  #1
Old 28-05-13, 01:23 AM
Crusher Crusher is offline
Newbie
Send a message via MSN to Crusher
Z87 waterblock
Hi there i was wanting to know if any one knew about the new Z87 motherbords. I have EK Supreme HES waterblock on my i7 950, i am looking to upgrade to a i7 4770k soon. I guess i will get to the point, will i need to buy a new waterblock for the 4770k or will one of the fittings that i got with the waterblock fit the new cpu/mobo.
  #2
Old 28-05-13, 01:28 AM
jamesriley94 jamesriley94 is offline
OC3D Elite
Z87 boards will run on the same mounting size as Z77 (and all other 1155 and 1156 boards).
As long as you have the fittings that are for 1155 or 1156, you will be fine.
  #3
Old 28-05-13, 01:41 AM
Newbie
awesome thanks for the fast reply. yeah i have the 1155 mounting bracket in the box waiting to go. can't wait to see how the 4770k overclocks on water i have heard some 1 getting 5ghz on 0.9 volts.
  #4
Old 28-05-13, 01:45 AM
OC3D Elite
Before the proper reviews go live, that doesn't mean anything.
For all we know, 0.9v on Haswell could be the maximum voltage these chips can take, and also might put out similar heat outputs to Ivy at high voltages.
All we've properly seen so far have been CPU-z screenshots, which don't replicate much into real world performance levels.
  #5
Old 28-05-13, 01:48 AM
Newbie
either way i am looking forward to see what can be done with them. TTL i am waiting
  #6
Old 28-05-13, 02:15 AM
SchaadeS SchaadeS is offline
Newbie
EK will most likely mail you a bracket if need be (if for some reason that previous person above me could be incorrect about the compatibilty). They often do that for free as well.
  #7
Old 28-05-13, 07:51 AM
Chopper3's Avatar
Chopper3 Chopper3 is offline
Member
Certainly Corsair's H100i has specified 1150 compatibility for a couple of weeks now.
  #8
Old 28-05-13, 08:59 AM
tinytomlogan's Avatar
The Guvnor
Some reviews are already up waiting to go live
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #9
Old 28-05-13, 10:45 AM
Noz_God's Avatar
Noz_God Noz_God is offline
Member
^^^^^^^^^^^^^^^^^^ cant wait to see them
__________________
My Rig|| Motherboard: Asus Maximus IV Extreme-Z || CPU: i7 2700k @ 4.6, 1.35v || Graphics Card: EVGA GTX 1070 SC ||
Memory: 16GB - G Skills Ripjaws Z @ 1866 || SSD: Crucial M4 128GB (OS) || HDD: Western Digital Caviar Black 1TB (Games) || Sound Card: Asus Xonar D2X || CPU + Mobo Cooling: Custom water cooling || Power Supply: Corsair TX950w ||
Case: Coolermaster HAF X
OC3D Overclockers Club Member #018
  #10
Old 28-05-13, 12:16 PM
Damien c Damien c is offline
OC3D Elite
Well looking on another forum, Gigabyte are doing something relating to what I can only assume is Z87 boards on the 3rd June 2013.
__________________
Gaming PC: AMD 5950X, 32GB Corsiar DDR4, MSI 2080Ti, Samsung 980 Pro 1TB NVME
Server PC: 2700x, 16GB Corsair DDR4, MSI GTX 1660Ti, Gigabyte 120Gb M.2, Crucial 240Gb SSD, WD Blue 500Gb SSD, 2x Seagate 6Tb HDD's
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
