  #1
Old 03-05-13, 02:01 PM
Froger Froger is offline
Member
Keyboards
hi, iv been looking for a gaming keybaord but i cant find one that suits me specificly, can anyone help? im not buying it right now but in the next few months.
i want a keyaord with a blue backlit
number pad seperate of the arrow keys
cherry mx blue
sold in the UK
(optional) media keys
iv done looking and i cant find any.
can anyone help?
budget is about 150 but all options are open.
  #2
Old 03-05-13, 02:12 PM
WillSK's Avatar
WillSK WillSK is offline
OC3D Elite
Send a message via Skype™ to WillSK
Would help if we knew your budget mate. Also I don't believe blues are THAT common in gaming keyboards unless you go to a dedicated manufacturer like Ducky or Filco.
My 2 cents, if you're looking for a very good value mechanical i am having no issues with my Steelseries 6Gv2 (cherry blacks)
__________________
My Rig : Fractal S2 Case, ASUS Crosshair VIII Hero, Ryzen 3800X, Corsair H115i Platinum, MSI GeForce RTX 2080 GAMING X TRIO, 32 Gb Team Pro Dark RAM 3200Mhz, Samsung 970 EVO SSD, Samsung 850 Pro 500GB SSD, Seasonic Prime Ultra Titanium
  #3
Old 03-05-13, 02:23 PM
Member
the main reason i want blues is for the clicky sound when i press down for typing, cause i do alot of typing, and the steelseries 6G2v is not backlit.
at the moment, if i go for cherry mx blue's then the CM storm quickfire TK.
or if i decide id rather have the number pad and aroow keys seperate but sacrifice the cherry mx blue's then il go for corsair k95 (cherry red) or k90 (cherry black)
and i dont have much of a budget but try keep it under 150 but mainly cheap as posible.
  #4
Old 03-05-13, 02:31 PM
WillSK's Avatar
OC3D Elite
CM storm quickfire TK would be an excellent choice! It got a great review on here too
__________________
  #5
Old 03-05-13, 02:33 PM
Tripp's Avatar
Tripp Tripp is offline
too many shrooms
Originally Posted by WillSK View Post
CM storm TK would be an excellent choice! It got a great review on here too
  #6
Old 03-05-13, 02:36 PM
Member
yeah im thinking of getting it, then il weigh up whether i need the seperate number pad or not and all that, thanks for the help.
  #7
Old 03-05-13, 02:42 PM
SPS SPS is offline
Moderator
I don't believe you can have all them features on one KB. The detachable numpad is hard to find that match the rest.
In fact the only backlit-mechanical gaming keyboard with detachable numpad I know of is the Mech5 which doesn't use blue switches and is red backlit.
  #8
Old 03-05-13, 02:54 PM
remember300 remember300 is offline
OC3D Elite
you could try the k95 which is what i have it lights up and has the macro keys but it also has a rear usb port which you could put a num pad into, if that helps, so you could use that off off the keyboard
__________________
  #9
Old 03-05-13, 03:06 PM
grassman's Avatar
grassman grassman is offline
OC3D Crew
I got the Storm Trigger 2 months ago. It burned out on me RMA'd it a few days ago. Waiting for it to come back oh god do I miss it loveee the thing..
If you do get it don't use the 5v power input. Coolermaster don't include the power supply for a reason
I got the brown, My wrist is killing.. Can't tell if carpel tunnel or my slave job is at fault. Although ever since RMA'ing it's been actually healing, While in possession it seemed to get worse and worse. Odd because if that is the case I haven't been on the computer much at all o_O Cherry MX Deathhhhhhhhhhh
__________________
R9 3900x | Gigabyte Master x570 | 32GB Corsair LED 3000 MHZ | EVGA RTX 3080 |
Swifttech h320 x2| Samsung 960 pro M.2 512GB | Corsair AX 1200i | Lian Li pc-011 |
  #10
Old 03-05-13, 03:24 PM
Tripp's Avatar
too many shrooms
wow mine has been working fine man i got the tk with the blue cherry mx, not sure what you mean about the power cable mine dont have a power cable input
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
