Go Back   OC3D Forums > [OC3D] Graphics & Displays > Screens and Displays
  #1
Old 19-09-12, 08:17 AM
Sileo Sileo is offline
Newbie
Question BenQ XL2420T Question
I am pretty sure that the monitor does not come with glasses but it does have an emitter so I was wandering what glasses I should buy. Can I buy any NVIDIA Vision glasses or do I have to buy a specific pair? Sorry if this is a noob question I have never used a 3D screen before.
  #2
Old 19-09-12, 11:38 AM
NRG!'s Avatar
NRG! NRG! is offline
Advanced Member
The xl2420t does not have an emitter.
The xl2420tx does. (Not sure if it comes with glasses)
Either way you need nvidia 3dvision/3dvision2 glasses. If you have the xl2420t then you need the separate emitter that comes bundled with glasses.
  #3
Old 19-09-12, 05:43 PM
XtremePhysX XtremePhysX is offline
Member
I have the xl2420t, amazing monitor in normal mode, I never use it in 3d.
Yes, I think you have to buy both emitter and glasses.
  #4
Old 05-10-12, 11:18 AM
Newbie
Okay thanks for the info, kind of sucks that you have to buy an emitter aswell as they are pretty expensive.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
