Go Back   OC3D Forums > [OC3D] Hardware & Software > Cases & Power
Thread Tools Display Modes
  #1
Old 27-01-15, 08:23 PM
artemis artemis is offline
Newbie
Cool Corsair CS450M
Hi,
I just watched the youtube video by Tiny Tom Logan on what size power supply to use and he suggested posting my rig specs for advice on wattage. Bit late in that I ordered a CS450M but I can return it if necessary. MSI Power calculator I just ran says 497w, Coolermaster says 331W??
My PC:-
Fractal Design R2 XL
3 fans
Gigabyte Z77X-UP5 TH
I7 3770 (not K)
4x4Gb DDR3 1333Mhz
GTX630
2xSata PCIEx1 cards
2xSSD 128Gb
6x2GB Hard Drives
1xDVD Drive (Not installed yet, thinking of LightScribe)
I mainly use it for programming, only thing that really stresses the processor is the Java Compiler, I have overclocked the CPU to 4.39Ghz and temps fine, currently using 340W PSU that doesn't have long enough cables for bottom mounting so it is sat in the 5.25 bays.
Can you tell me whether the 450W will be sufficient to be safe please?
Regards,
Phil
  #2
Old 27-01-15, 08:31 PM
MadMarc's Avatar
MadMarc MadMarc is offline
OC3D Crew
Unless you plan to upgrade your GPU soon, 450w is enough for your rig
__________________
  #3
Old 27-01-15, 08:34 PM
Feronix's Avatar
Feronix Feronix is offline
OC3D Elite
Yeah, Tom ran the i7 + 780 Ti on a 450 Watt PSU and that card draws a LOT more power than a GT 630. Seems to me like the Cooler Master calculator was more accurate.
I suspect MSI are going with 'better safe than sorry' in this case. Either way, it'll be fine
__________________
~Rick
"If a bear looks good in the woods when nobody is there, is he still a cool ass motherf***ing bear?" - JR23
  #4
Old 28-01-15, 07:35 AM
Newbie
Thanks
Thanks for the fast response.
  #5
Old 28-01-15, 04:18 PM
Lystfiskern Lystfiskern is offline
OC3D Crew
you have overclocked a non k 3770 to 4,39 Ghz ?
__________________
[SIZE="2"][FONT="Book Antiqua"]Fractal Design Define R5W White / Corsair AX760i[/ EVGA Z97 FTW / Intel® Core i7-4790K / 32GB Kingston HyperX Savage 2400Mhz / Samsung 850 Pro 250Gb/Corsair Force Series GT 240Gb / HGST 4Tb / Seagate Barracuda 3Tb / MSI GTX970 Gaming / Corsair H100GTX - Corsair SP120QE / Dell Ultrasharp U2410/ Corsair AF140QEx2 Front / Corsair AF120QEx2 Bottom/Back
Tags
cs450m 3770 z77x-up5
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
