Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
Thread Tools Display Modes
  #21
Old 10-01-19, 08:29 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Originally Posted by TheF34RChannel View Post
They really need to optimize their stuff, rather than suggesting otherworldly specs. The same happened with 1, for example steam areas tanked performance etc.
Having said that, alpha performance on my system was lackluster and needed serious graphical down tuning to achieve playability. It might improve with the final product, of course.
They did show the game at minimum settings and maximum settings and just like the first one there isn't that much difference so running at max settings is only really useful for screenshots IMO.
__________________
  #22
Old 11-01-19, 02:42 PM
Damien c Damien c is offline
OC3D Elite
My system will not run this at 1440p 60FPS at high
This is the game that, is going to cause me to probably switch my systems around and put my 1700x in my main machine, and look at overclocking it because the 7700K is not enough.
I will be pre-ordering this at the end of the month, because I will be playing this on day 1, difficult to say anything without breaking rules
__________________
  #23
looz's Avatar
looz looz is offline
OC3D Elite
1700x will not run games better than the 7700K.
__________________
i7 8700k - 16GB - 2060 FE - 512GB 970 & 850 EVO - AKG K702
  #24
Old 11-01-19, 03:21 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Depends. There were certain levels in Crysis 3 that had the FX 8320 trounce the 2500k.
If a game calls for cores and they are not there it runs like dog doo, no matter how fast those four cores are. It's like trying to run RT on hardware without Tensor/RT cores.
__________________
"Those really high 20 series prices are just place holders"
  #25
Old 11-01-19, 03:32 PM
looz's Avatar
OC3D Elite
No it doesn't depend, 7700k will not get choked like 4c/4t i5 CPUs.
__________________
  #26
Old 11-01-19, 03:52 PM
OC3D Elite
The issue is that the Snowdrop engine prefers cores over core speed, but I will be able to test it when the game releases as all I need to do is swap GPU's.
__________________
  #27
Old 11-01-19, 09:18 PM
TheF34RChannel's Avatar
TheF34RChannel TheF34RChannel is offline
OC3D Elite
Originally Posted by Warchild View Post
Me and you Fear. Tearing it up in washington!
Okay, I more or less caved and will likely pick this up shortly after launch so yeah, let's tear it up!
What will you get?
  #28
Old 11-01-19, 10:04 PM
AlienALX's Avatar
OC3D Elite
HT "cores" provide about 30-35% of the grunt of a real core by all accounts.
So I'll believe it when I see it.
__________________
  #29
Old 12-01-19, 06:25 AM
OC3D Elite
What will you get?
At the moment I have 2 systems.
One has a 7700k with a 1080ti, the other has a 1700x with a 1060 3Gb.
If the 1700x and 1080ti offer more fps than the 7700k and 1080ti then I will look at getting a 2700x for my main machine, and give my dad my 7700k as he needs a upgrade.
However if the 7700k and 1080ti offers more fps then I will just leave the systems as they are, and wait till AMD release the 3000 series of cpu's.
__________________
  #30
Old 12-01-19, 01:34 PM
Dicehunter's Avatar
Resident Newb
While the 7700K is still a decent chip it is still only a quad core and more and more games now prefer as many cores as they can get their hands on.
I believe it was the latest BFV that showed this as well as several AC games when comparing quad cores to newer hex and octo cores, I know in The Division with my 2700X I get a much MUCH smoother experience than I did when I tested a 6700K which is basically nearly identical to a 7700K.
__________________
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
