Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
  #1
Old 21-04-21, 09:15 PM
WYP's Avatar
WYP WYP is offline
News Guru
Microsoft's redesigning its App Store to revitalise Windows 10
This is a gamechanger for Windows 10.
Read more about Microsoft's plans to redesign its Windows 10 App Store.
__________________
_______________________________
Twitter - @WYP_PC
  #2
Old 21-04-21, 10:11 PM
KingNosser KingNosser is offline
OC3D Crew
I've always disliked the store, espeically when they use it to patch windows in the past what is the point of windows update if they don't use it for that sole reason.
It works but like most things it could be a lot better.
__________________
https://forum.overclock3d.net/attachments/signaturepics/sigpic20429_1.gif
  #3
Old 22-04-21, 03:14 AM
AMD Enthusiast
Many reasons to do that and that's why the industry is moving towards that way of updating. For example Android is moving towards this way of updating almost everything through the Play Store.
By making things more modular they can update independent frameworks without needing a full update that requires a restart. You can make this happen with security updates or app updates reserving actual OS related modules/kernel to a full blown required restart and takes a few minutes.
This allows for faster and easier updates which makes it more likely to be updated on more devices, reducing the amount of versions installed which makes debugging easier for customer support and just plain making things simpler for development. Which then leads to less bugs.
Very excited for this change. Would be nice if they allowed you do what GoG does and show different storefront games where you can launch from one store.
  #4
Old 22-04-21, 07:21 AM
ET3D ET3D is offline
Member
This could change the app store from an undesirable feature to a very useful one. It would certainly be nice to have a one stop shop to get all software. Of course, developers will need to get on board, but with all limitations gone, that's more likely to happen.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
