Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
  #1
Old 06-03-21, 05:58 PM
Etihad Etihad is offline
Newbie
Manual stable OC - Unable to load windows in Adaptive 10900k 5.2GHZ All core
Hi All,
So i'm still in dire need of some help. I have a manual stable OC in Manual Mode @ 1.420 Vcore in bios. Idle load voltage is 1.40, under cinebench load 1.250v. All temps are fine, see attached image. I have a 5.2GHZ Overclock with 0 AVX. 53GHZ on 4 core load LLC 4 Cache 4.8GHZ.
I cannot for the life of me just enter 1.420 in Adaptive with 0 Turbo boost Offset. As soon as it try to load windows with Adaptive @ 1.420, when I reach the circular boot loading screen it freezes. I have changed LLC all the way upto 7 and still I have no luck. WHAT IS GOING ON. I have been at it for hours 😞
The only way I can actually use my setup is by loading on Manual. I don't know how to use Offset.
Motherboard is Asus Maximus Extreme XII
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
