Go Back   OC3D Forums > [OC3D] Hardware & Software > Software Section > Games
  #21
Old 19-01-13, 10:54 PM
SeekaX SeekaX is offline
OC3D Elite
i'm a little short on money atm. i will build a rig for a friend of mine and it will be quite good, i will try it in that PC. still 23 months left to return it if its faulty.
also the card is performing as good as it should in 3d benchmarks, so i doubt that the card itself is damaged. but i don't know how the architecture works either.
  #22
Old 20-01-13, 01:33 AM
SPS SPS is offline
Moderator
Well if it's under performing in 2D rendering then something isn't correct.
  #23
Old 20-01-13, 12:04 PM
OC3D Elite
I just started the single player on maxed out settings and it's performing as it should. GPU load goes up to 80-100% and the CPU is at 80-95%. Avg is about 90 fps which they achieved in the benchmarks as well.
  #24
Old 20-01-13, 12:09 PM
iBeInspire iBeInspire is offline
OC3D Elite
Seriously, try completely removing your 2D profile in Afterburner... For me it's caused nothing but problems ~
__________________
/|i5 4690k @4.6Ghz @1.315v /|\ Asus Z97-AR /|\ 8Gb G.Skill RipjawsX /|\ Asus GTX970 Strix |\
/|TX550m /|\ Samsung 840 Pro |\
/|Asus Essence STU /|\ Hifiman HE-400S /|\ AKG K551|\
[OFFICIAL] OC3D Overclockers Club Member [#025]
  #25
Old 20-01-13, 12:30 PM
OC3D Elite
i already removed it, it wouldnt let me monitor my fps anymore.
anyways, in muliplayer, same settings, the GPU only goes up to 60% load, as soon as the chat or any other overlay kicks in, the frames drop to 30 and the gpu load to 30%.
  #26
Old 20-01-13, 12:41 PM
OC3D Elite
after i was about 10 minutes in the game the monitoring bugged, it said my fan speed, temp and load was at 0% and the core clock at 500mhz. shortly after when i tabbed out of the game the driver crashed.
  #27
Old 20-01-13, 01:29 PM
OC3D Elite
Going on a whim here, but try closing afterburner completely and then running the game...
Use the console to bring up an FPS counter and see if that makes a difference
Afterburner cause me big problems in DX9 games before I updated it, maybe that's your problem... Even if it is up to date, worth a try right..?
__________________
  #28
Old 20-01-13, 01:32 PM
OC3D Elite
i ran the game in dx11, can't use ingame fps since bfbc2 has no console but afterburner caused me trouble as well, back when i used the old gpu it would crash after 10 minutes with afterburner running. but i will give it a try anyways
  #29
Old 20-01-13, 07:43 PM
OC3D Elite
i just had some artifacting in cod4. it's weird because neither the gpu or the cpu was at high load and the temps were both under 50°C.
  #30
Old 20-01-13, 07:53 PM
OC3D Elite
I'm bordering on just shouting out defective :/
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
