Go Back   OC3D Forums > [OC3D] Hardware & Software > Sound Cards & Speakers
Thread Tools Display Modes
  #11
Old 28-12-18, 01:23 PM
Avet's Avatar
Avet Avet is offline
OC3D Elite
You can make it yourself, or ask anyone in electric repair shop to make it for you. It is a 15 min job. Electronic stores, or music stores sell connectors. Cable you can buy in spools. Just take the length you need, split it at the ends, and solder connectors. Components are available from budget to studio level. And you can easily make it much higher quality than you can find in stores. That one in the picture is really bad.
  #12
Old 28-12-18, 01:50 PM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
Why is the one in the picture bad?...
  #13
Old 28-12-18, 03:03 PM
Avet's Avatar
OC3D Elite
That cable is too thin. If you peel it you will see maybe 5 thin wires for each connection. Surface of the wire is what transmits the signal. More wires, more surface, better signal.
It depends on your needs, but i prefer to spend the same, or a little more on a custom cable if i can't find quality one, and know that i can plug anything in it. That one is good for Skype headphones. If you have 300€ headphones, or speakers and put it in that cable, you wasted money on headphones.
A decent copper cable, with good connectors will give you less hiss sound if you use it as an extension.
  #14
Old 28-12-18, 04:42 PM
looz's Avatar
looz looz is offline
OC3D Elite
Yeah nah that cable is likely fine even for hifi headphones. The current is very low.
__________________
i7 8700k - 16GB - 2060 FE - 512GB 970 & 850 EVO - AKG K702
  #15
Old 31-12-18, 07:40 PM
Warchild Warchild is offline
OC3D Elite
So you want one cable that splits into 2 to support both mic and audio?
Check out plantronics. They might be able to help you. They have an assortment of cables for their professional headsets as well as gaming.
I have made my own in the past. But I honestly don't see whats wrong with the one you posted. Both cables or stuck together so it's as neat as its going to get.
Check
Soundblaster
Plantronics
Logitech
Clas Ohlson
Vention
dhgate.com
  #16
Old 31-12-18, 08:18 PM
Dawelio's Avatar
OC3D Elite
Yes, that is correct. But more one cable that splits into 2 female connectors on one end and male connectors on the other.
There’s nothing wrong with the one I posted, just wondered if anyone might have something different and perhaps a shorter option than that.
  #17
Old 01-01-19, 08:33 AM
scubasteve scubasteve is offline
Advanced Member
this is the extra cable that came with my v-moda M-100's its what you are looking for ? works great never had any problems with it
only place i did find it was on their actual site for 9 bucks
https://www.v-moda.com/us/en/product...pc-mic-adapter
Edit : i lieeee i just put Voip-Pc Mic Adapter inot amazon and like 5 thousand came up
  #18
Old 01-01-19, 11:11 AM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Nah that's a phone 4 pin to mic and headphones. He needs basically two cables in one.
__________________
  #19
Old 01-01-19, 06:08 PM
OC3D Elite
I would just buy 2 single cables and wrap them in a custom sleeve. That is all it is after all.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
