Thread Tools Display Modes
  #1
Old 10-01-14, 03:43 PM
NiklasHein NiklasHein is offline
Newbie
Post Watercooling for new Setup
Hey folks.
Im going to start my first Buildlog really soon on this Forum.
Just wanted to hear your opinion on the parts I picked out.
It's gonna be a beast!
Parts:
Hardware:
1. 2x WD Black 1TB
2. 2x SSD 840 Evo 250GB
3. i7-4770K
4. Corsair Vengeance LP 16GB (2 sticks)
5. 2x Gainward GTX 780 TI Phantom
6. Asus Gryphon Z87
7. Asus Gryphon Armor Kit
8. ASUS PB278Q, (27“, 120hz, 2560x1440)
9. Corsair Carbide Series Air 540
10. Corsair RM Series RM750
Watercooling:
1. 5x Corsair Air Series SP120 PWM Performance Edition High Static Pressure
2. EKWB EK-Supermacy Acetal Nickel
3. 2x EKWB EK-FC 780 GTX Nickel
4. 2x EKWB EK-FC780 GTX Classy Backplate
5. EKWB EK-RES X3 150
6. EKWB EK-DCP 4.0
7. EKWB EK-CoolStream PE 240
8. EKWB EK-CoolStream PE 360
9. 8x EKWB EK-CSQ 45° Adapter G1/4
10. 6x EKWB EK CSQ 90° Adapter G1/4
11. EKWB EK-CSQ Fitting 10/16mm G1/4 4x
12. EKWB EK-FC Bridge DUAL Serial CSQ
13. Masterkleer Schlauch klar, 3/8“ 5/8“, 10/16mm, 3m
14. Shoggy Sandwich V2
Price is going around 3.800€ so if you have ANY suggestions. Let me hear it!
Thank you,
Niklas
  #2
Old 10-01-14, 03:53 PM
jamesriley94 jamesriley94 is offline
OC3D Elite
Moved this over to new build advice.
Why are you getting an mATX motherboard for an ATX case?
The new Vengeance Pro series is also a lot nicer looking than the older LP stuff, so I'd suggest you swap to that since the budget is there.
Finally, the waterblocks for the graphics cards aren't compatible. You'd be better off switching to reference design cards.
  #3
Old 10-01-14, 09:36 PM
Newbie
1. Pricing. I don't Wang to Pay any more than necessary. The only other motherboard I'd buy would be the saber tooth.
Which is like 50€ more.
2. Well pricing again.. If it ain't look good it shouldn't be visible at all.. The only other RAM I like would be the Corsair Pro Series which would be another 40€...
3. Well, the water blocks claim to be compatible on the EKWB configurator. Otherwise I'd take some EVGA cards as I really like the manufacturer.
  #4
Old 10-01-14, 10:25 PM
Warchild Warchild is offline
OC3D Elite
I would kind of advise against the DCP 4.0. It's Noisy!
I once had it and if your just throwing all components in the case for performance then its fine. If you want the system to look good, the DCP 4.0 is ugly and somewhat difficult to find an optimum placement to hide it conveniently without taking up much space.
I would opt for the MCP35x, tiny in comparison, performs WAY better and its much quieter
Look into your EK bridge connector and make sure its compatible with the GPU blocks. GPU blocks are kinda new and not compatible with slightly older bridges.
  #5
Old 11-01-14, 09:39 AM
Newbie
Well, silence would be good, but isn't necessary.
I like the look of the EKWB Pump. In my sketch up it fits just fine. I cannot tell a lot about noise levels since this is my first water cooled build..
The bridges should probably be compatible. Since it's both EKWB. Though I couldn't find any compatibility list about them.
Thank you for the suggestions and tips so far.
Do you have any other advices? E.g which coolant? I'd like to go for a white.. But I don't know the market well...
Or are there other possibilities for the pump?
Cheers, Niklas
  #6
Old 11-01-14, 09:50 AM
OC3D Elite
well if you go for Mayhem Pastel colours, dont use primochill tubing as it stains them very quickly.
Personally I use EK coolant. Reviews were good and gives a nice UV green colour. Maybe you should contact EK and ask if that bridge will be compatible with the gpu blocks. Just because they are all from EK doesnt mean they are compatible. Different GPU blocks need different bridges. e.g my bridge for the 680 cards was not compatible with the 780 blocks. Obvious reason behind it but still should consider.
I use the MCP35x pump now, its 50% smaller, much more powerful and quieter than the dcp4.0. Im not a fan of these pump/drivebay res combos either. I have it set to 30% and it cant be heard yet still pumps like a monster.
  #7
Old 11-01-14, 09:59 AM
Newbie
Okay, I'm going to contact EKWB for the bridges these days.
Is there other manufacturers for tubing I can consider to buy? I don't want to have any other colors then black an white in the water cooling setup. So I'd stick with white coolant. Maybe adding some blue with LEDs later.
I will post some pictures of the 3D model I'm working on later this day.
  #8
Old 11-01-14, 06:53 PM
OC3D Elite
You can still use masterkleer tubing. There is also XSPC, Thermochill, Clear Flex, Masterclear and a few other brands
Just ensure Primochill or Tygon is NOT used. It literally clouds up the tube in just 2-3 days.
  #9
Old 14-01-14, 09:03 AM
Newbie
Oh, by the way! Is it possible to change the sata cables on the back of the hot swap drives?
Tags
beast, rig, setup, suggestion, watercooled
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
