Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
  #1
Old 08-03-21, 12:09 PM
WYP's Avatar
WYP WYP is offline
News Guru
AMD's FidelityFX Super Resolution reportedly Doubles Game Performance - A DLSS killer
Radeon's multi-platform performance booster!
Read more about AMD's FidelityFX Super Resolution feature reportedly doubling game performance.
__________________
_______________________________
Twitter - @WYP_PC
  #2
Old 08-03-21, 02:10 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
DLSS killer ? That's an enormous claim, It'll be a welcome alternative but I'll take this with a truck load of salt.
__________________
= Steam/Origin/Uplay - Dicehunter =
  #3
Old 08-03-21, 02:27 PM
Dark NighT's Avatar
Dark NighT Dark NighT is offline
OC3D Elite
Bit sensational i agree, when the cold hard numbers of this come in then we can see if it really does what it says and if it's a "killer" or not.
__________________
Rig: Cpu: AMD R7 3700X. Mobo: Gigabyte X470 Aorus Gaming 7 wifi. Ram: Gskill Royal Silver 3200mhz cl16: Gpu: Msi RTX2070 Armor. Asus Xonar STX II.
  #4
Old 08-03-21, 02:31 PM
WYP's Avatar
WYP WYP is offline
News Guru
If it works as intended and is fully cross-platform (including Nvidia), it will diminish the appeal of DLSS.
If AMD can match Nvidia in terms of quality, Nvidia will have a hard time keeping developers interested.
__________________
Twitter - @WYP_PC
  #5
Old 08-03-21, 03:30 PM
Dicehunter's Avatar
Resident Newb
It'll be interesting to see how it's implemented as Nvidia use dedicated hardware for it but from what I have read AMD do not have dedicated hardware for this type of thing which going by what I know of RDNA2 it will use a cards compute ability meaning it wouldn't give the same level of performance uplift as Nvidia's Tensor cores.
Could be totally wrong though and AMD have some secret hidden special sauce hardware.
__________________
  #6
Old 08-03-21, 08:58 PM
ImprovizoR's Avatar
ImprovizoR ImprovizoR is offline
OC3D Crew
At this point, who the hell cares. Unless crypto market crashes, I see no point in even following the GPU market.
  #7
Old 08-03-21, 09:03 PM
AngryGoldfish's Avatar
AngryGoldfish AngryGoldfish is offline
Old N Gold
I think it's fair to say it could be a DLSS killer in that it could offer greater performance uplift and reach a wider audience. DLSS may still end up being visually superior, especially as it ages, but the main issue with DLSS at the moment is implementation. Even if AMD are late, if they come out with something at least somewhat visually comparable, with greater performance gains, and wider implementation, that could 'kill' DLSS in the same way that Freesync 'killed' Gsync. It obviously won't just as Freesync didn't actually kill Gsync, because the technology is very good and Nvidia has its foot in many companies' doors, but Freesync as it currently is is effectively superior. It's cheaper, easier to implement, and works across multiple systems. If AMD had the financial clout and foothold as Intel, Gsync would have no place.
It seems to me that DLSS vs FidelityFX Super Resolution is a repeat of that. DLSS isn't used for anything other than gaming, it can't be used by any other manufacturer, it has to be implemented by the game developers but isn't available on the two main consoles, and it has costly hardware demands. Those are some pretty big drawbacks.
DLSS is awesome and it's in Nvidia's future for sure, but I do think AMD's answer could 'kill' it.
__________________
ASUS X370 Crosshair VI Hero ⁞⁞ Ryzen 1600X 4Ghz ⁞⁞ Thermalright Le Grand Macho RT ⁞⁞ Aorus GTX 1080 11Gbps ⁞⁞ G.Skill TridentZ 3200Mhz
Jonsbo W2 ⁞⁞ Corsair AX760 ⁞⁞ Pexon PC ⁞⁞ Samsung 960 EVO 250GB & 850 EVO 500GB
⁞⁞ Western Digital 1TB Blue & 3TB Green
BenQ XL2730Z ⁞⁞ Mixonix Naos 7000 ⁞⁞ Corsair K70 Cherry MX Brown ⁞⁞ Audio-GD NFB-15 ⁞⁞ EVE SC205 ⁞⁞ AKG K7XX
  #8
Old 08-03-21, 09:17 PM
Dicehunter's Avatar
Resident Newb
From the bits I've read, AMD's version will be heavily based on Microsofts Direct ML image upscaling so for games on PC this should be incredibly easy to implement, Compared to DLSS.
__________________
  #9
Old 08-03-21, 10:40 PM
AMD Enthusiast
DLSS code is provided as a toolkit. It's not like they each do it from scratch.
Remains to be seen for FidelityFX SR. Wouldn't surprise me but this does create issues still with segmentation. Even if they adopt it, if based on DXML it will not be cross compatible with PS. Which then begs the question of if we already support DLSS, why bother adding this for one platform(XBOX)? It wouldn't be worth the time to implement and remove DLSS(from PC) to add it to both Xbox and PC considering most studios only just have gotten DLSS.
  #10
Old 09-03-21, 01:30 AM
looz's Avatar
looz looz is offline
OC3D Elite
Source: YouTuber says so
__________________
i7 9900k - 16GB - 3080 XC3 Ultra - 660p 1TB + MX500 2TB - HE-4XX w/ Topping D30+A30
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
