  #31
Old 17-05-13, 02:56 PM
AMD Enthusiast
I get it makes sense
  #32
Old 17-05-13, 09:35 PM
Xenomorphical's Avatar
Xenomorphical Xenomorphical is offline
Member
Where is your videocard going to be tho? no way it can fir on the MOBO with that huge rad blocking its normal position?
  #33
Old 17-05-13, 09:36 PM
pcjunkie429's Avatar
pcjunkie429 pcjunkie429 is offline
Member
Z77 mobo has onboard video . He doesn't need a dedicated GPU since this rig is only going to be used for home server/HTPC duties.
__________________
NOT Lee Harrington (owner of PCJunkie Mods), just a fan of his.
PC Specs (as of 4/15/2013): AMD FX 8150 (OC to 3.87 GHz using AMD Asetek AIO Liquid Cooler), 8gb of Kingston HyperX Black Edition 1600 MHz DDR3 RAM, Sapphire Vapor-X AMD Radeon 7770 GHz Edition, WD Caviar Blue 500GB, SeaSonic X Series 600w PSU, Zalman Z12 Plus case
  #34
Old 17-05-13, 09:44 PM
Member
Ah ok nm my previous post then about the GPU part.
Still, isn't the whole watercooling part a bit overkill for a home server then tho?
That unless its meant to be a that, and a watercooling project in one
__________________
Infinite creativity!!
  #35
Old 17-05-13, 10:01 PM
alpenwasser's Avatar
alpenwasser alpenwasser is offline
OC3D Elite
Don't worry about the GPU part, you are not the first one to raise that question (and it is a
legitimate question I'd say), and I doubt you'll be the last.
I'll also be doing BOINC, so the CPU will run @ 100% 24/7 (at least that's the current plan).
So there will be plenty of heat to dissipate. Since it's supposed to be rather silent I thought
some W/C would be appropriate (it will be in our living room after all, albeit hidden in a sideboard
that can be closed). And yes, the other reason is simply that I love to tinker around with W/C,
and I still had the stuff from my previous rig, so why not use it?
Thanks for stopping by!
  #36
Old 18-05-13, 12:29 AM
Member
Originally Posted by alpenwasser View Post
And yes, the other reason is simply that I love to tinker around with W/C.
All i needed to hear hehe.
But yeah a massive rad with that many fans on low speed should do the trick easy!
__________________
  #37
Old 18-05-13, 12:41 AM
AMD Enthusiast
I know what you are trying to say but z77 does not have onboard video. It supports it and the cpu has the onboard gpu
  #38
Old 18-05-13, 12:44 AM
Member
I meant that his particular z77 mobo has onboard video capabilities. Y u so literal?
__________________
  #39
Old 18-05-13, 02:05 AM
AMD Enthusiast
literal? Ok then...
All Z77 mobos come with onboard capabilities and can be used if the system does not have a dedicated gpu.
That better? lol
  #40
Old 18-05-13, 05:05 AM
njallday's Avatar
njallday njallday is offline
Member
literal? Ok then...
That better? lol
Hate to be a downer, but the graphics are located on the CPU chip nowadays, not on the motherboard's chipset
__________________
i5 3570k 4.5 GHz MSI Z77A-G45 Corsair Vengeance 8gb EVGA GTX 670 AX 650 Samsung 830 256gb NZXT Switch 810 Custom Watercooled
Tags
360 radiator, black and blue, fractal design r4, modding
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
