Go Back   OC3D Forums > [OC3D] Cooling Forum > Liquid Cooling
Thread Tools Display Modes
  #11
Old 14-01-19, 02:41 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
I would be concerned about an air pocket in that case. You've definitely totally saturated the components. Like I said though, expect the 20 series to run hot. It's the first time Nvidia have put out a kitchen sink since Fermi.
__________________
"Those really high 20 series prices are just place holders"
  #12
Old 14-01-19, 02:46 PM
Warchild Warchild is offline
OC3D Elite
all in all though, 50C is not bad at all. Mine hits 50C on both cards heavily overclocked with 2x 480 rads. The fans are however only at 35% PWM so its silent running.
Don't overthink it. If you start hitting the 60s with your setup on the GPU, then it might be time to look into things. For now, enjoy your custom loop
70 on cpu and 50 on gpu are perfectly fine
  #13
Old 14-01-19, 03:00 PM
Kaapstad's Avatar
Kaapstad Kaapstad is offline
OC3D Elite
2080
Don't run that hot.
Don't use that much power.
Even my RTX Titans only use 280w TDP which is a lot less than some cards I can think of.
__________________
OC3D Overclockers Club Member
#041
GTX 960 owner and proud of it.
  #14
Old 14-01-19, 03:19 PM
tgrech tgrech is offline
OC3D Elite
280W is still quite a lot for a stock card, it's more than FuryX/390X was, the only modern cards it's less than really is 290X/Vega64/some other Titans. The 2080 is a 225W card, so slightly more than Vega56, I'd say anything beyond 200W you could say is a hot card, remembering anything with only an 8-pin can't use more than 216W (On the relevant 12V line) while in spec.
  #15
Old 14-01-19, 03:26 PM
looz's Avatar
looz looz is offline
OC3D Elite
The large die size helps with transfering the heat though.
__________________
i7 8700k - 16GB - 2060 FE - 512GB 970 & 850 EVO - AKG K702
  #16
Old 14-01-19, 03:38 PM
OC3D Elite
For the Titan/2080Ti yeah, the 2080 has a smaller die than Vega & Fury however, & the decrease in area for the 2080 is much larger than its decrease in power consumption against the Ti.
  #17
Old 14-01-19, 06:47 PM
Kei's Avatar
Kei Kei is offline
Advanced Member
RTX 2080Ti Die Size: 754 mm˛ TDP: 250 W
RTX 2080 Die Size: 545 mm˛ TDP: 215 W
Vega 64 Die Size: 495 mm˛ TDP: 295 W
Smallest die is vega, biggest TDP is vega. My Vega 56 with 64 bios, +150% power target and a hefty overclock pulls over 300W and will sit at roughly 58 degrees being cooled by an EK block and 420 and 240 radiators. Dropping from 1.2V to 1.05V drops the power draw to roughly 230W and the temperature doesn't get over 50. This is in a room ambient of 24 and the case internal temp is 32.
So GPU delta is 18 degrees above case ambient.
__________________
Gigabyte Aorus X399 Gaming 7 ⁞⁞ Ryzen TR 1920x ⁞⁞ EK Blocks + αcool XT45 rads ⁞⁞ AMD Radeon Vega 56 ⁞⁞ 32GB 8 Pack 3200C14 ⁞⁞ Enthoo Primo
Seasonic Prime 750W ⁞⁞ Polaris 961 256GB ⁞⁞ 850 Pro 512GB ⁞⁞ M500 240GB ⁞⁞ WD Se 4TB & 1TB x2 ⁞⁞ Samsung C27HG70 + Dell 2408WFP
Ducky Shine 5 ⁞⁞ AJA Kona LSe ⁞⁞ RME HDSPe AIO ⁞⁞ Marantz AV7701 ⁞⁞ Tannoy SRM 10B ⁞⁞ AKG K601 ⁞⁞ Beyer DT770
  #18
Old 16-01-19, 02:27 PM
trawetSluaP's Avatar
trawetSluaP trawetSluaP is offline
OC3D Crew
Thank for all the feedback ie saying temps are fine as well as the suggestions and recommendations too.
Am gonna have a little jiggly about with the loop over the week end, change the bottom rad to intake and check the blocks and paste are OK to be thorough.
Will report back if there's any change.
Thanks again for the help.
__________________
Enthoo Elite | i9-7900X | Rampage VI Extreme | Dominator Platinum 32GB | RTX 2080 FE | 960 Pro 512GB, 840 Evo 250GB x 2 | EVGA SuperNOVA 1200 P2 | PG279Q, MX27AQ | Custom Watercooling Loop + Aquaero 6 XT
  #19
Old 21-01-19, 11:19 AM
OC3D Crew
Right, jiggling complete.
Bottom rad changed to intake.
Idle temps for GPU and Water have dropped by 5-6C.
Load temps for Water and GPU have dropped 5-6C and CPU load temps have dropped by 8-10C.
A small change but definitely worth doing!
__________________
  #20
Old 21-01-19, 11:51 AM
OC3D Elite
Great to hear. I guess your chassis air flow has also improved with this. Its more uniform now, and not pulled in different directions. And that temp change is alot. Not a small improvement!
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
