Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #1
Old 06-11-18, 05:10 PM
tolagarf's Avatar
tolagarf tolagarf is offline
OC3D Crew
Help Finding Sleeved Cables for HX1000 PSU
I need some better cables for this PSU (Platinum edition) as the ones provided are really stiff and causes clutter in certain places. Problem is I can't seem to find any cable sets that supports this PSU.
Been looking at Corsair's website, there are some cables there but they all specifically does NOT mention HX series, only HXi series. Besides that they are shrink wrapped at the connectors. So I looked at CableMod, also here agin their cables does not mention HX series only HXi, except their new Pro series of cables. But those cable sets are not complete from what I can tell. Seems like they are missing a few PCI-e and SATA cables.
Any suggestions, or could someone actually provide info on the HX vs HXi difference besides from the HXi being digital. Seems the cables don't match?
Edit: I need RM/RMi cables for the Platinum version of HX1000? That it?
  #2
Old 06-11-18, 07:59 PM
Eddie long's Avatar
Eddie long Eddie long is offline
Advanced Member
I think BitFenix CSR range are compatible with that PSU
__________________
Life isn't always a bowl of cherry's.
Sometimes it's HARD WORK
  #3
Old 06-11-18, 08:37 PM
WillSK's Avatar
WillSK WillSK is offline
OC3D Elite
Send a message via Skype™ to WillSK
best thing to do is email cablemod direct. I did that in the past when I needed some cables for my AX when only the AXi was listed and they pointed me in the right direction.
I believe the HX and HXi are different OEMs so I would assume the cables are not compatible
__________________
My Rig : Fractal S2 Case, ASUS Crosshair VIII Hero, Ryzen 3800X, Corsair H115i Platinum, MSI GeForce RTX 2080 GAMING X TRIO, 32 Gb Team Pro Dark RAM 3200Mhz, Samsung 970 EVO SSD, Samsung 850 Pro 500GB SSD, Seasonic Prime Ultra Titanium
  #4
Old 06-11-18, 08:41 PM
tolagarf's Avatar
OC3D Crew
I looked for those but it seems they're not being sold in Denmark anymore, and hard to find in Germany as well. Well at least Caseking will have them in stock by 2nd of January
https://www.caseking.de/en/bitfenix-...-zuad-608.html
The Cablemod kits have too few cables in the bundle for HX series because they are meant for the RM / RMx series, same with the Pro kit. Who puts in only 3 PCI-e cables? That makes no sense to me at all.
  #5
Old 06-11-18, 10:26 PM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
Why don't you do custom cables from CableMod? Excellent cables and their customer service is spot on. I've personally ordered some of their ModFlex cables to my old Corsair HX750i and they were spot on.
Here you go to their configurator: https://store.cablemod.com/configurator/
  #6
Old 06-11-18, 10:39 PM
tolagarf's Avatar
OC3D Crew
Way too expensive. Would cost me 239 euros for a full set of cables
Edit: Found and bought the Bitfenix Alchemy 2.0 CSR Black cables from Overclockers.uk. They had one left in stock
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
