Go Back   OC3D Forums > [OC3D] Customer Care Forums > Corsair Customer Care Forum
Thread Tools Display Modes
  #1
Old 06-05-18, 05:53 PM
jesse525 jesse525 is offline
Newbie
commander pro and H115 pro
I just semi-finished a new gaming pc, for the build i purchased a commander pro, an h115i pro RGB, and a few RGB maglev fans with the lighting node.
First, I couldn't get the fans LED to work. Then I had the lighting node wire melt to the USB cable, yes I said melt, but that's that not the problem, I already have that getting replaced
The actual problem now is I cant get the H115i pro to show up in my Corsair Link. I have uninstalled the Link software and reinstalled it with the older version, which didn't help. Could my commander Pro be faulty or is it the cooler?
Click image for larger version
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
