Go Back   OC3D Forums > [OC3D] Graphics & Displays > Overclocking
Thread Tools Display Modes
  #21
Old 02-02-14, 03:33 AM
Harishanim Harishanim is offline
Member
OK i finally cornered the problem! it's speed step! i read on intel's page that when speed step is one it'll scale performance to 0 and idle frequency at 800MHz, now the thing is , i can't seem to find speed step anywhere in the BIOS
FOUND IT!! another spin through the manual told me where it was, I've disabled it, but still the speed is at 800MHz i started writing a cd and for a second it cranked to 3.5GHz and back to 800MHz
__________________
  #22
Old 05-02-14, 11:04 AM
Prathamesh Patil Prathamesh Patil is offline
Newbie
Send a message via Skype™ to Prathamesh Patil
go to the cpu options in main tab in bios and disable the c6,c7 states. also check the multiplier of the cpu i.e cpu ratio.
  #23
Old 05-02-14, 11:22 AM
tinytomlogan's Avatar
The Guvnor
If you had followed the guide you wouldnt have had these problems. Ive done all the hard work all you have to do is listen.
/over&out
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #24
Old 05-02-14, 02:49 PM
Member
It was nothing related to softwares, apparently the slow mode switch on the damn (useless) oc panel was on
__________________
Tags
bios, overclock motherboard
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
