Go Back   OC3D Forums > [OC3D] Hardware & Software > Cases & Power
Thread Tools Display Modes
  #1
Old 27-03-13, 08:38 AM
alpenwasser's Avatar
alpenwasser alpenwasser is offline
OC3D Elite
What Advantages Does Great Voltage Regulation Have?
Hello everyone,
For the past few years I have spent dozens of hours scouring the web for PSU reviews (mostly just out of curiosity), and while I'm more or less clear (I think) about why you need low ripple and good transient responses, I have not found much useful information on voltage regulation.
To clarify a bit: I am not so much interested in out-of-spec behavior. Naturally, in those cases things go bad rather quickly, from instability, refusal to start to actual component damage.
What I'm interested in much more is the difference in practice between somewhat below average (but still completely in spec) and phenomenal voltage regulation. What advantage(s) does great voltage regulation actually give you as opposed to just something halfway decent?
Since all thorough PSU reviews I've read place a rather high importance on this (meaning great and not just in-spec voltage regulation), I presume it has to be quite important.
  #2
Old 31-03-13, 09:23 PM
NRG!'s Avatar
NRG! NRG! is offline
Advanced Member
When you say voltage regulation, don't you mean ripple? as in: better voltage reg = lower ripple.
Potentially better component lifespan, higher stable overclocks, etc.
OCZ ZX 850w:
my gtx 680 ltg needed +50mV on memory voltage to reach it's max o/c (forgot what it was now)
Corsair AX1200i:
same card doesn't need any memory over voltage to reach max memory o/c
(680 ltg pulls memory power through pci-e 8pins, not pci-e bus)
  #3
Old 31-03-13, 09:26 PM
Rich_ Rich_ is offline
Member
Better voltage regulation = less significant 'power spikes' to your components. Theres a select few 'high end' 800+w psu's, i believe Tom did a video on one, and these PSU's will actually kill components in a matter of weeks because of the power spikes.
__________________
Zalman Z9-U3
i7 3770k 4.5ghz
Corsair H70 Core - Xigmatech push, generic pull.
GTX 560 superclocked 930mhz
Zephyr 720W PSU
Crucial Ballistix Tracer orange/blue 4GB 1600mhz
Sandisk SSD 120GB
  #4
Old 01-04-13, 09:25 AM
OC3D Elite
Ah, yes, my apologies, should have clarified better.
I didn't actually mean ripple (I think), what I meant could more accurately be described as "how close are the actual voltages to their nominal values over the power spectrum from idle to full power".
So, for example, when drawing and providing little power (idle), the +12 V rail might supply 12.1 V, and when on full power, the 12 V rail might actually be only 11.9 V.
As an example of what I mean, see the graphs titled "Load Regulation" on this review.
I did indeed watch Tom's vid where the tested PSU blew up, and jonnyguru actually does articles from time to time where they go out and buy a cheap PSU just to see if they can blow it up by testing it to its full specs
What I conclude from both your answers and my previous knowledge is this:
  • A PSU which provides voltages too high above spec (say, 12.8 V on the 12 V rails ) may kill components, or at least shorten their lifespan significantly, same goes for serious ripple and spikes during transient loads (I suspected this already, but I'm writing it here for completeness).
  • A PSU which provides voltages below spec (e.g. 11.8 V on 12 V rails), while not harmful to components, might require more voltage tweaking on your components to reach a certain overclock (for example, the graphics card NRG! mentioned). If so, this is the answer to the question I actually meant to ask (clever me ).
If I've misunderstood anything, I would be grateful for any corrections/clarifications. Thank you both for your help!
  #5
Old 03-04-13, 04:51 PM
Christoi Christoi is offline
Newbie
From what I've seen, at lot of these tests are to make sure that the power supply doesn't damage the components it's connected to, which can be a problem with low-end units. If the unit is within the ATX spec, it's generally considered to be fine, though naturally lower is better.
By reviews, it's often used to analyse the quality of the output current and compare it with others. Even a lot of low-end units (eg: CX-series, Antec VP-series, CM GX-series) are within safe levels, so most reviews aren't actually testing whether the unit is safe or not. Rather, it's more of a quantitative way of comparing different units.
Do be aware however, that it doesn't really say much about the actual quality and longevity of the unit itself. Units with better regulation tend to have longer lifespans, but it's not a direct trend. A good example of this is the digital power control of the AX-i series, the added circuitry allows for insanely accurate voltage regulation, but that alone does absolutely nothing to the reliability of the unit.
Also, ripple tends to be what can affect stability, as it's about very small deviations of voltage (usually ~0.05v). If this is high enough components like the CPU may suffer given the fluctuating voltage, causing stability issues. Similarly with voltage regulation however, past a point, it really doesn't make much of a difference.
Personally, while I do use this as a point to see how good a unit may be, I really don't see the quality of the output current as much of an issue in a lot of cases. In my opinion, the larger reason to buy a high-end, expensive power supply is the added reliability and longevity, which is achieved by using higher-quality components.
  #6
Old 03-04-13, 05:38 PM
OC3D Elite
Yeah, that's generally the impression I got as well.
Indeed. I had a professor who was very adamant about keeping systems simple: "Every additional component adds at least two possible points of failure: Itself and any interface/connection to the remaining system. So any advantages it adds must be weighed against that very carefully.", is what he used to say.
Ripple is very important in control engineering, of which I've had two semesters, but naturally we never used it in context with a computer
This is why I went for the Enermax Platimax 1200. Voltage control (specifically, voltage drop over the power spectrum) is, while totally within spec, not exactly phenomenal (the remaining performance criteria are very good from the reviews I've read; excellent ripple control, transient response etc.). However, the build quality and component choice are absolutely stunning, and I sort of have a fetish for that
Thank you for your answer!
Tags
atx, psu, voltage, voltage regulation
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
