Go Back   OC3D Forums > [OC3D] Hardware & Software > Cases & Power
Thread Tools Display Modes
  #41
Old 02-07-08, 08:48 AM
mrapoc mrapoc is offline
OC3D Elite
Im in for a cube case!
nice to see you mark
erm
big enough for current and future hardware
a good position for the rad (perhaps up to 360mm rad?)
yeh, good cooling for the summer
watercooling ofc
some place to route cables?
some mesh/window (altho mesh does look cooler)
so large enough for all current and future standard hardware, but to be able to stick a handle or something on it so it aint a pain to carry to lans
flatpack ikea style ftw!
wonder what the estimated cost will be? we could have quite a demand for these
__________________
  #42
Old 02-07-08, 10:18 AM
nunzio nunzio is offline
OC3D Crew
I'm up for a Cube for ma new system.. has to be able to hold two loops on 240 or bigger rads tho.
Maybe something with a PVC (windowed) top/side depending on the mobo setup.
I dont know about the rest but 2x 5 1/4 bays external and 4x HDD bays internal would suit me.
  #43
Old 02-07-08, 05:41 PM
markkleb markkleb is offline
OC3D Elite
its looking like air is out and water is in. I will sit down and figure some sizes in a bit.
Originally Posted by name='PV5150'
Hi Mark
It's awesome to see you back again and even better knowing what you're doing. Congrats on your recent success too
Thread named changed as per Tox's request and thread stuck for the time being to ensure it doesn't disappear
Thank you PV5150
__________________
Thanks
  #44
Old 02-07-08, 06:38 PM
OC3D Elite
wiked man
look forward to some designs xD
__________________
  #45
Old 02-07-08, 08:27 PM
OC3D Elite
Hello mrapoc.
I was looking at a triple rad I have and its 15.5" in length(sorry I grew up before the metric system)
The Qpack case if I remember was 14" deep 10" wide and 9" tall
http://www.newegg.com/Product/Produc...82E16811144111
Is this similar to the shape you want? and if you want room for the triple I could just add an inch or so to the length.
Or do you want a double or a double and a single(2 loops)
__________________
Thanks
  #46
Old 02-07-08, 09:22 PM
OC3D Elite
heyyy
well anything cubular in shape and not as big as that lian li recently reviewed.
that case looks ace, maybe a bit small. as for loops, iv only ever done one loop and it was fine, but as others may want the same design perhaps offer the option to either have 2/3 fans on one side, or an extra rad.
edit: i found that the mountain mods H2GO had everything i was after
__________________
  #47
Old 02-07-08, 10:13 PM
OC3D Elite
if i can get you to agree on the shape of the Qpack I can make a case about 1" taller 1 1/2" longer and 1/2" wider to house a dual rad and a single (with 1 or 2 pumps/loops) or a triple rad (single loop).
It would mount any GPUs (2,3 or 4) and any size PS as well.
__________________
Thanks
  #48
Old 02-07-08, 11:06 PM
OC3D Elite
looks about right to me mate, and personally id just go for a triple rad and not bother with two loops.
what kinda airflow are we gonna look at as well?
thaanks
__________________
  #49
Old 02-07-08, 11:41 PM
OC3D Elite
you all need to agree on the Rads first. Airflow will be superior to any existing SFF case.
How many Hdds do you all want to have room for?
Also can you use Laptop DVD or do you require reg size DVDs?
give me some Ideas of the mobos, PSs, and GPUs that may be used.
__________________
Thanks
  #50
Old 03-07-08, 06:07 AM
Toxcity Toxcity is offline
OC3D Elite
Triple Rad sounds okay to me. People with a double (like me) can use the extra space for other things.
I would rather use a Regular sized DVD drive.. dunno about everyone else. With hardware I was thinking of High-End gear. Full ATX stuff.
Someone else can elaborate.
__________________
Main System: Intel i5 2500K @ 4.8Ghz, 8GB Corsair Vengeance 1866Mhz, Geforce GTX 560 Ti
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
