Go Back   OC3D Forums > [OC3D] Hardware & Software > Cases & Power
Thread Tools Display Modes
  #151
Old 28-01-09, 02:55 PM
Hodgstar Hodgstar is offline
Member
there are some more pics in this old thread
http://forum.overclock3d.net/showthr...light=hodgstar
__________________
MOBO:----Biostar TPower Intel X58
CPU:------ i7 920 Cooling:- swiftech Storm.
MEMORY---Corsair 6GB DDR3 Dominator PC3-12800C8 1600MHz
GRAPHICS--4850 512mb with EK full block
PSU--------ETITIS 850
CASE------- Lian-li PC70 Currently being Modded(see Project Hodgstar)
  #152
Old 17-04-12, 05:36 PM
Carl A Carl A is offline
Newbie
Hello All,
I am looking into ATX Cube cases and struggling to find anything that I can afford at the mo. After much reading have decided on building / modding one myself using 2 ATX cases as the bones of the beast. Now, cost is a real bone of contention for me.
I need to fit in an ATX MB, D5 Pump, 1x360 Rad and a large reservoir. I Know that this would fit into a tower ATX but want something different that I have put something personal into. Given that, can anyone recommend or point me to a cheap ATX case that 2 could be used for the bones. I Am looking for as plain a case as possible so that when 2 are joined they look uniform, a mesh design would be nice. I am happy to get to work with a dremel so no windows is fine (actually better).
Hope you can help, thanks
Carl
  #153
Old 17-04-12, 07:35 PM
Toxcity Toxcity is offline
OC3D Elite
Hey Carl!
Ressurrected this thread from the dead. Not complaining! I would personally prefer people used the search function of the forums rather than starting a hundred threads about the same thing.
I really like your idea. Have you had a look around eBuyer, Aria, Scan, etc for a bog standard case?
__________________
Main System: Intel i5 2500K @ 4.8Ghz, 8GB Corsair Vengeance 1866Mhz, Geforce GTX 560 Ti
  #154
Old 17-04-12, 09:42 PM
Newbie
Hi Nic,
I Have indeed and figure that one with plainest front would work best when the two are sandwiched together....1 case to house the MB and Res with a window which I will cut, the other to hold a 360 Rad, Pump & PSU. The most work that I can forsee would be cutting the front of case 2 so that I can get the rad/fans in there but space won't be a problem
I am thinking about 2 of of these, I know they are cheapos but like I said, price is a big consideration for me -
http://www.aria.co.uk/Products/Compo...roductId=47468
Or this, more costly but I figure better quality cases and finish -
http://www.ebuyer.com/278066-nzxt-so...e-nzxts210e001
  #155
Old 18-04-12, 12:15 PM
Newbie
OK, got impatient LOL !!!!
Ordered 2 of the cases from Aria - £49 Delivered
and the following from Specialtech -
- Akasa Low Profile VGA RAM Heatsink 10 Pack Black : AK-VMC01-BK
- Swiftech MCR320XP Extreme Performance 360mm Triple Radiator : MCR320XP
- 4 1/4" Thread High Flow Barb Fitting for 1/2" (13mm) ID Tubing : Black
- Phobya Balancer 250 Reservoir Black Nickel
- XSPC 7/16" ID - 5/8" OD (11-16mm) High Flex Tubing : Clear
- Mayhems Aurora Fluid for Water Cooling 3 Litres : Nebula Blue
- £129 delivered
Let the fun times begin !!, My dremel had better watch out
  #156
Old 26-05-12, 06:40 PM
Bullmecha's Avatar
Bullmecha Bullmecha is offline
Advanced Member
Sooooo anything happening here?
Interested to see what the sandwich case will look like
__________________
Asus Z170-A - I5 6600K (OC 4.2) - 16GB Ripjaw V -Sapphire Radeon HD 7870 Ghz - Samsung 850 EVO 120GB - White NZXT 810 Switch
  #157
Old 27-05-12, 04:28 PM
Newbie
Sure, it's still a bit 'work in progress' so bear with me
Need to install lighting, coasters, sort cabling, cut a window and finish off the rough bits. Pretty pleased with the temps so far given that it's a slim 360 but there is plenty of space for more rads . Akasa fan controller turned out to be a waste as it suffers from a buzzing (should have read the forum reviews first !!!). Just ordered a zalman zm-mfc1 so that it's a bit quiter, when I have some cash the fans need to be made a little more uniform.
By cabernethy1 at 2012-05-27
  #158
Old 27-05-12, 06:09 PM
wassupdoc's Avatar
wassupdoc wassupdoc is offline
OC3D Elite
umm, what?
The front doesn't look anywhere near uniform lol, you should get an aluminium or acrylic plate and make a front panel, would look so much better - and you should remove the front io ports from both cases and relocate, just my 2 cents
__________________
"Entertaining by default"
  #159
Old 28-05-12, 06:03 PM
yassarikhan786's Avatar
yassarikhan786 yassarikhan786 is offline
OC3D Elite
Originally Posted by wassupdoc View Post
umm, what?
This^^
__________________
Motherboard: Asus P8P67 Pro (B3) || CPU: i7 2600k || Graphics Card: EVGA GTX 780 Ti ACX || Memory: 16GB - Mushkin Blackline 8GB + Corsair Vengeance LP 8GB || SSD's + HDD's: Samsung 850 EVO 500GB (OS + Programs) + Caviar Black 2TB (Games + Storage) || CPU Cooling: Noctua NH-D14 || Power Supply: BeQuiet Dark Power Pro P9 750W || Case: Corsair Obsidian 650D || Monitor(s): Dell U2410 + HP w1907v
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
