  #11
Old 16-07-15, 01:00 AM
Josrey Josrey is offline
Newbie
Originally Posted by NeverBackDown View Post
It's an odd combo because it's a low end CPU paired with a quite a mid to high end GPU. That's all he was saying on that
True but the 860K overclocks quite well and with more programs making use of more than 2 cores it is a fairly good cheap quad core CPU combined with a relatively high end GPU should perform well in games.
  #12
Old 17-07-15, 12:30 PM
Newbie
Okay so my sexy LP Vengance 8GB kit (2x4G 1600Mhz RAM came today :P pics to follow
  #13
Old 20-08-15, 09:24 PM
Newbie
Case came yesterday and has the above components already installed.
  #14
Old 20-08-15, 10:15 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Pics or it didn't happen.
__________________
If you don't like what I post don't read it.
  #15
Old 22-08-15, 07:44 PM
Newbie
sorry just havent got round to taking any yet will do tomorrow and post them.
  #16
Old 27-08-15, 03:18 PM
Newbie
I promised you all pictures so here are a few of the build so far.
Click image for larger version
ID:	10482   Click image for larger version
ID:	10483   Click image for larger version
ID:	10485   Click image for larger version
ID:	10486   Click image for larger version
  #17
Old 27-08-15, 06:21 PM
AMD Enthusiast
Not bad but the cable management could use little more work on the front. Like the front IO could be routed behind the tray and come up from underneath instead of across the board
  #18
Old 27-08-15, 10:07 PM
Newbie
The front IO is routed behind the tray the only cable that goes across the board is the front fan cable as its not long enough to go under the tray
  #19
Old 29-10-15, 02:03 AM
Newbie
So i've got myself a really cheap GTX 680 coming from my uncle along with a 21" widescreen LG mointor so hopefully will get this built by next week.
Tags
860k, amd, build, first build, gaming
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
