Go Back   OC3D Forums > [OC3D] Off Topic > Off Topic Chat
Thread Tools Display Modes
  #10361
Old 22-11-19, 02:49 AM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
I bought an Amazon Echo Show 5.
I wanted a bedside alarm clock I could ask for the time as I wake up a lot in the dark. I also want it for asking the weather, to know if it's even worth getting up etc. Wanted one for ages but was waiting for black Friday. Saved £30.
__________________
  #10362
Old 23-11-19, 05:23 PM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Going to be vertical mounting my 2080 Ti FE in my Corsair 680X which comes with built in support so got myself the Phanteks Premium riser cable, No idea what makes it premium though
__________________
=Origin-Steam-Uplay-XBLive - Dicehunter=
  #10363
Old 23-11-19, 05:28 PM
AlienALX's Avatar
OC3D Elite
Yeah my Lian Li has built in support. Made it easy.
__________________
  #10364
Old 23-11-19, 07:35 PM
Dawelio's Avatar
Dawelio Dawelio is offline
OC3D Elite
The name
  #10365
Old 24-11-19, 03:30 PM
tgrech tgrech is online now
OC3D Elite
Not my purchase but helped a friend spec/build/iron out an ITX PC recently and he decided to go for those new black 92mm Noctua fans to finish off the aesthetics, end result is quite nice:
Before-
After-
  #10366
Old 24-11-19, 03:32 PM
Dawelio's Avatar
OC3D Elite
Before-
After-
The colour makes all the difference Nice one!
I wonder though, how are those in comparison to the slim 92mm?...
  #10367
Old 24-11-19, 09:06 PM
OC3D Elite
According to Noctua the slim version had 25% higher RPM, 92% of the max static pressure and 72% of the max airflow.
https://noctua.at/en/nf-a9-pwm-chrom.../specification
Slim: https://noctua.at/en/nf-a9x14-hs-pwm.../specification
  #10368
Old 24-11-19, 10:30 PM
Dawelio's Avatar
OC3D Elite
Yeah, that I know... But wondering about the noise comparions specifically. The specs say one thing, but the real world noise is another.
  #10369
Old 25-11-19, 08:52 AM
OC3D Elite
I see, well their dB specs are probably pretty accurate for comparing such similar models I'd think, but it;s worth bearing in mind frequency also has an effect on our ears, and ofc 25% higher RPM means 25% higher frequency too, which is psychologically more annoying. No way to measure or communicate that really.
  #10370
Old 25-11-19, 01:18 PM
FTLN FTLN is offline
OC3D Elite
Direct die getting dropped of tomorrow.
Any body know of any cases that can handle a horizontal E-ATX instead of vertical ?
__________________
Intel Core i9 7980xe @ 4.5GHz @1.18v - MSI MEG X299 - NoName 2666mhz @ CL19 3200mhz - Thermal Take View Glass - PM961 1TB x2 - Aorous Extreme RTX 2080 Ti - 2 x 360 Rad + D5 Pump - Asus ROG Swift PG279Q 2560x1440P G-Sync 165Hz
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
