Go Back   OC3D Forums > [OC3D] General Forums > OC3D News
  #1
Old 15-08-18, 12:45 PM
WYP's Avatar
WYP WYP is offline
News Guru
Overclocker cranks AMD's Ryzen Threadripper 32-core to 6GHz
Moar power!!!
Read more about AMD's Ryzen Threadripper 32-core being clocked to 6GHz.
__________________
_______________________________
Twitter - @WYP_PC
  #2
Old 15-08-18, 01:50 PM
Dark NighT's Avatar
Dark NighT Dark NighT is offline
OC3D Elite
That is just insane.
32 cores running that speed. the power draw is going to be so high.
  #3
Old 15-08-18, 02:25 PM
g0ggles1994's Avatar
g0ggles1994 g0ggles1994 is offline
OC3D Elite
I read on Reddit that during the first stable OC of 5.3GHz, the entire system swallowed 1.2kW of power so I would assume increasing to 6GHz would put it in the region north of 1.5kW.
Comparing that to Intel's 28 Core 5GHz OC, that needed 1kW just for the CPU and a further 1kW for the cooler. That's 2kW discounting the rest of the system which comparing it to the ThreadRipper CPU is just insane
__________________
Ryzen 1700X @ 3.6GHz | MSI X370 Gaming Pro Carbon | Corsair H100i v2 | 16GiB Corsair Vengeance LED Blue
ASUS RoG Strix Vega64 8GiB | 2TB WD SN750 | Corsair RM850 CableMod | Phanteks Enthoo Pro M TG
  #4
Old 15-08-18, 03:52 PM
RobM's Avatar
RobM RobM is offline
OC3D Elite
pretty amazeballs OC that but boy the power draw must be insane
__________________
ASUS ROG Crosshair VII wifi | Ryzen 5 3600 | Custom Loop | Patriot Viper Steel 4133 @ 3600 2 x 8Gb | Asus Strix RX 470 | Samsung 500gb nvme | Samsung 1Tb nvme | Samsung Evo 120gb ssd | Seagate Barracuda 1tb storage | Toshiba 1Tb HDD | EVGA 500w | Phanteks Entho Pro Tempered Glass | Windows 10 and Linux Manjaro
  #5
Old 15-08-18, 04:37 PM
AMD Enthusiast
It could probably run crysis by itself at that speed with all those cores
  #6
Old 15-08-18, 04:56 PM
dugdiamond's Avatar
dugdiamond dugdiamond is offline
OC3D Elite
cool for LN2. the hype will be over soon.
i have read many other reviews of this cpu, and some apps do not perform well with it.
these are the very same apps that the consumer would have been buying this cpu for.
__________________
Prepare for the worst. Assume losing. Then... if the opposite occurs... BONUS!
  #7
Old 15-08-18, 05:52 PM
Gothmoth Gothmoth is offline
Advanced Member
a german websites reports that there are issues with TR 2990wx and nvidia cards.
they replaced a nvidia 1080 TI with a radeon vega 64 and the framerate increased a lot.
for one title it nearly doubled.
https://www.golem.de/news/32-kern-cp...08-136016.html
  #8
Old 16-08-18, 02:11 AM
Kleptobot's Avatar
Kleptobot Kleptobot is offline
Advanced Member
could be related to DX12 implementation, i know AMD did a fair bit of work regarding multi threaded command buffering so maybe that is bearing fruit with the massive number of available threads
__________________
delided 3570k (watercooled)
hd7970 (watercooled)
8GB Gskill XM
3*140 SR1 Rad
all stuffed in an FD arc midi
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
