Thread Tools Display Modes
  #1
Old 08-09-17, 02:47 PM
MT. Mods MT. Mods is offline
Member
Exclamation Pocket Rocket - Turning a quad bike, into a gaming/show system!
Welcome to my Project logs of 'Pocket Rocket'
What's the deal ?
For this project, i'll be transforming a brand new 50cc mini quad bike into a full gaming/show system.
I'll be removing the engine and replacing it with the motherboard and GPU's
I'll then replace the exhaust system with reservoirs and tubing.
There's still some stuff to figure out, but very soon i'll get the quad and figure out all that.
Special thanks to my wonderful partners
ASUS Republic Of Gamers UK
Thermaltake technology inc.
TeamGroup Global
Cablemod
Specs
Intel core i7 7800X
ASUS ROG Sytrix X299-XE gaming
ASUS ROG Strix 1080 OC
TeamGroup T-Froce Delta R 16GB DDR4
Cablemod Custom cables (Pro Kit with aluminium Combs)
Cablemod RGB/W Lighting
Thermaltake
Riing Plus 12 RGB Radiator Fan TT Premium Edition
Toughpower Grand RGB 850W Gold Fully Modular
2x Pacific T22 Reservoir's
Pacific P1 Black D5 Pump w/ Silent Kit
2x Pacific V-GTX 10 Series Transparent (ASUS ROG)
Pacific W4 Plus CPU Water Block
Pacific M-Pro G1/4 PETG 12mm Fittings - Black
Pacific G1/4 PETG Tube 90-Degree - Black
Pacific G1/4 PETG Tube 45-Degree - Black
Pacific G1/4 Pressure Equalizer Stop Plug w/ O-Ring - Black
Pacific G1/4 Female to Male 20mm Extender – Black
Pacific G1/4 Y Adapter – Black
Pacific Drain Valve – Black
Pacific G1/4 Stop Plug w/ O-Ring – Black
Pacific G1/4 Male to Male 10mm Extender – Black
x3 V-Tubler PETG Tube 12mm OD 10mm ID 500mm 4 Pack
Thermaltake Pacific Hard Tube Bending Kit for ID 10mm x OD 12mm Hard Tube
Thermaltake C1000 Opaque Coolant Black
Thermaltake Pacific RL360 Radiator
Photo's!
So... Here's some photo's of the quad, it's due for delivery on monday, excited to start.
So the quad measures at 1 meter long, 60cm wide and 60cm tall. (Tons of space!)
One of the first things i'll be doing is removing the panels from the quad and spraying the underside of them, hate seeing that white.
ASUS ROG UK Delivery.
First up: Strix X299-XE Gaming motherboard
Strix 1080 OC edition graphics cards
ASUS ROG HB SLi bridge
TeamGroup Global T-Force Delta R kits
Will update more as the final parts arrive, this is to be hopefully completed BEFORE EGX!!
Insane time frame, but i must try
Thanks for looking.
  #2
Old 09-09-17, 12:00 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Well this is certainly different will be watching with interest
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
  #3
Old 12-09-17, 09:52 AM
Member
That's for sure! haha
Update 1:
Quad bike has arrived, and put together.
Currently deciding on where components should go.
Will be removing the engine a little later tonight, when the kid goes to bed
Thanks for checking out my logs
-Craig
  #4
Old 12-09-17, 09:54 AM
tinytomlogan's Avatar
The Guvnor
This is very cool!
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #5
Old 12-09-17, 01:34 PM
Bartacus Bartacus is offline
OC3D Elite
Cool project! I've only ever seen one mini bike project, but that was a mini build on a running bike. I like this idea better, gutting it completely!
__________________
Guts: Ryzen 2700X / Asus CH7 Hero / 32GB TridentZ RGB 3200CL14 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: ADATA SX8200 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads / Barrow box reservoir / dual D5 pumps
  #6
Old 12-09-17, 01:39 PM
AlienALX's Avatar
AlienALX AlienALX is offline
OC3D Elite
Asouter's?
__________________
"Those really high 20 series prices are just place holders"
  #7
Old 12-09-17, 01:40 PM
OC3D Elite
I can only see X's from work, but pretty sure that was the modders name, bad memory serving!
__________________
  #8
Old 12-09-17, 01:43 PM
AlienALX's Avatar
OC3D Elite
Mini Moto Mayhem. Only thing I didn't like was the crushed velvet seat. Bit camp for me.
__________________
  #9
Old 12-09-17, 01:45 PM
WYP's Avatar
WYP WYP is offline
News Guru
I am looking forward to seeing more.
__________________
_______________________________
Twitter - @WYP_PC
  #10
Old 12-09-17, 01:50 PM
Member
Thanks guys!
Yeah i'm sure i've seen that mini moto before too. Looks good
Already got the engine out, and test fitting the Motherboard and graphics card.
So far. it's a perfect fit. Will get an acrylic plate made for the motherboard later.
Tags
crazy, gaming, quad, scratch
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
