Thread Tools Display Modes
  #1
Old 06-09-17, 04:06 PM
Jokot Jokot is offline
Newbie
Project JDM | ITX scratch build!
Project JDM
So its finally time to start on a new build log this time of a project i call "JDM". The core inspiration of the project was Japanese styled drift cars hens the radiator with outwards mounted ports to illustrate a oil cooler. And the other big small thing that is that i wanted it to be in mini-ITX format. So after a few weeks of thinking i decided to go with a tube frame to keep it true to the theme. Here are some of the renders i made after some designing in Fusion 360. Also big thanks to Alphacool, Bequiet and Teamgroupe for helping out with the hardware.
  #2
Old 11-09-17, 04:32 PM
Newbie
First update to start things off.
One of the first obstacles i encountered was the corner pieces. I had a few options but after some thinking i decided to make some custom 3D-printed parts for the job.
These are the 2 versions I made but I ended up going for the simpler design.
First print turned out great!
Removing the support material.
  #3
Old 11-09-17, 05:43 PM
Wraith's Avatar
Wraith Wraith is offline
Bettyswollocks
Nice start to the build and 3D printing too! Love it.
__________________
“A person who never made a mistake never tried anything new.” ~ Albert Einstein
  #4
Old 11-09-17, 06:18 PM
WYP's Avatar
WYP WYP is offline
News Guru
It is nice to see some 3D printing be used in a big case build project. Looking great so far.
COnsider me subbed!
__________________
_______________________________
Twitter - @WYP_PC
  #5
Old 11-09-17, 08:00 PM
You_What? You_What? is offline
OC3D Crew
3D printing? Count me in! /Subbed!
  #6
Old 17-09-17, 02:02 PM
Newbie
COnsider me subbed!
Thanks
  #7
Old 17-09-17, 02:04 PM
Newbie
Starting on the metalwork.
I will be using some 16/14mm metal pipes for the frame
Test fitting.
  #8
Old 17-09-17, 07:47 PM
sheroo's Avatar
sheroo sheroo is offline
OC3D Elite
Looks great.
__________________
"All his life has he looked away... to the future, to the horizon. Never his mind on where he was."
  #9
Old 01-10-17, 04:43 PM
Newbie
Originally Posted by sheroo View Post
Looks great.
Thanks
  #10
Old 01-10-17, 04:45 PM
Newbie
More metal work.
Making the support for the front radiator.
I made a bracket from wood to make the welding a bit easier.
Ready to start welding.
This is what it looked like with no clean up and still 2 pieces left to go.
Now lets clean it up a bit.
Tags
mini-itx, scratchbuild, water cooled
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
