Go Back   OC3D Forums > [OC3D] Processors & Platforms > Mainboard & CPU
Thread Tools Display Modes
  #11
Old 21-07-17, 05:52 AM
datacenter datacenter is offline
Newbie
Hello guys,
Did anyone get a -20 degrees on the CPU temps. My idle temp is now 23 (before they were around 43) and the room temperature is 27.
The CPU is 1700X, so there is that dumb 20 degree nonsense and the skim is on auto by default.
Any ideas, fixes?
Thanks!
  #12
Old 21-07-17, 06:25 AM
Dicehunter's Avatar
Dicehunter Dicehunter is offline
Resident Newb
Well it definitely won't be lower than your rooms ambient temp, Probably a bug and not being read properly.
__________________
- Intel Core i9 9900K @ 5GHz - Asus ROG Max XI Hero -
- Corsair Vengeance Pro RGB 4x8GB @ 3600MHz -
- WD Black SN750 1TB - GTX 1080 Ti FE @ 2000/6000 -
- Windows 10 Pro 64 Bit Edition - Corsair 680X Black -
  #13
Old 21-07-17, 08:01 AM
Newbie
Yeap, exactly. I could probably play with SKIM and make it look more realistic... but still I am hoping someone have a clue?
  #14
Old 21-07-17, 10:31 AM
BigDaddyKong's Avatar
BigDaddyKong BigDaddyKong is offline
OC3D Elite
Try disabling SenseMI Skew to clear up the temp readings.
__________________
AMD R7 1800X-Asus Crosshair VI Hero-16GB GSkill 3200mhz-Corsair HX850-H110i-MSI 1070-Coolermast H500-Windows 10 Pro-Dell U3011-Dell 2007FP
  #15
Old 21-07-17, 11:06 AM
tinytomlogan's Avatar
The Guvnor
Originally Posted by datacenter View Post
Hello guys,
Any ideas, fixes?
Thanks!
Thats just the offset thats been removed. AMD added 20c onto the 'X' cpu's
Id ignore the 'idle' temps though they have always been iffy
__________________
If you recommend a product LINK THE REVIEW
Get along or run along. Your choice
  #16
Old 21-07-17, 03:45 PM
RyzenMaster's Avatar
RyzenMaster RyzenMaster is offline
Newbie
Originally Posted by 10thDmenxn View Post
Well, did you ever get it to 3200? I don't mean to be contrary, but can't understand why so many on here never report back, as that is what this forum is for.
Sorry for now posting sooner. My Adata XPG 3000 memory was able to overclock to 3260 MHZ with full stability.
Cinebench Score went from 1666 to 1720
I am able to get a stable overclock of 4.0Ghz on the CPU, but the voltage required is higher than I would like so I kept it lower.
Ryzen 7 1700 @ 3.875GHZ
Adata XPG 3000 AX4U300038G16-DRZ
  #17
Old 21-07-17, 03:57 PM
Bartacus Bartacus is offline
OC3D Elite
If anyone is adventurous and interested in testing a beta BIOS, Elmor from Asus just released one minutes ago. You can find the OCN post here:
http://www.overclock.net/t/1624603/r...#post_26237954
As per Elmor:
Got a BIOS for you guys to test. C6H BIOS 9920 SHA256 968558A4710C8F8BE67FED3B6ABDF35F29A1C6FDFDC157F648 95CA0E264826EE
* Improved DRAM cold boot, results in slightly longer POST time
* Fix for CPU Ratio stuck at 22x on some CPUs when using Vcore override/offset
* SenseMi Skew is now Disabled by default. If you want to return to previous behavior set SenseMi Skew = Enabled and Offset = 272.
* Added DRAM profiles for Samsung B-based DIMMs with tuned subtimings, including The Stilt's settings
* Maybe a few other extras, you tell me
FYI gents. I'll be flashing this one ASAP as soon as I get home!
__________________
Guts: Ryzen 3900X / GB Aorus Master / 16GB TridentZ 3600CL15 / Zotac GTX 1080Ti x2 / EVGA 1000W PSU / Case Labs M8
Storage: Corsair Force MP600 1TB NVME / 6TB RAID0 HDD array / 4TB RAID0 SSD array
Water Cooling: Watercool HeatKiller IV blocks on CPU & GPUs / 4 360 rads + 240 rad / Heatkiller reservoir / dual D5 pumps
  #18
Old 25-07-17, 05:02 AM
AntonS AntonS is offline
Newbie
Hello guys,
Any ideas, fixes?
Thanks!
I've got just the same issue on my Ryzen test rig. CPU temps are crazy, jumping from 27 to 45 on idle back and forth this causes CPU cooler - AIO Corsair H115i increase RPM and noise. Interesting is there any way to get stable and actual CPU temp?
  #19
Old 25-07-17, 05:44 AM
Korreborg's Avatar
Korreborg Korreborg is offline
OC3D Crew
Change the fan profile = Problem solved.
__________________
[I9-7900X][Asus Strix X299-E][EVGA 1080TI FE][Corsair 16GB 3733MHz][Fractal Meshify C][Corsair AX860i]
[Samsung 970evo 500GB+1000GB of mixed SATA SDD's][ASUS PG278QR][Logitech G510s and G502][Steelseries Wireless H]
Tags
bios, crosshair vi, motherboard, update
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
