Thread Tools Display Modes
  #1
Old 10-02-17, 07:42 PM
gadgetjoe gadgetjoe is offline
Newbie
Post Alter-ego
Hello! Im Joe Campbell, Owner of YouTube channel Gadget Joe and im a reviewer/videographer and modder from Grimsby, UK.
My latest project build is Alter-Ego, a custom desk build (yes another desk build!) with a unique one of a kind twist! Work and play built into one unit with 2 systems and 2 different personalities!
Sponsored by Alphacool/Aquatuning and Mayhems.
Aquatuning and Alphacool sponsor all the liquid cooling components, radiators, tubing, blocks and more.
Mayhems sponsor the maintenance of the loop and system in form of Blitz Kits.
Specs:
(main system)
Mobo: Asus M5A97 LE R2.0
CPU: AMD FX 8350
RAM: Kingston 1600mhz 16gb (2x8)
PSU: 500w
GPU: Radeon RX480 8gb
SSD: 120gb Hyper-X
HDD: 500gb+320gb HDD
(watercooling loop - Parts being provided by Alphacool/Aquatuning)
Alphacool Eisbrecher Pro XT45 240mm Rad x2
Alphacool VPP655 Eisdecke D5 x2
Alphacool Eisbercher Lite 250mm Plexi x2
Alphacool Eisblock XPX CPU Chrome
Alphacool NexXxosS GPX 480 Gpu Block
Alphacool Susurro Fan 120mm x4
Multiple Alphacool chrome fittings
13/10 PETG and Soft tubing
Alter-Ego is a 6ft long by 38" wide desk with main system built into a white gloss box that sits at 24"x32" sunk into left hand side housing main system with polished glass top, Test bench with AIO to the right of the desk in an 8" recessed white gloss box. Top is burnt and stained pine, rest is white with burnt pine accents and LED backlighting and RGB LED embedded around the build. Wall mounted triple monitor setup. Power switches from main to test bench with one button. 2x reservoirs with different shades of UV blue each powering GPU Block and CPU block respectively, Hard tubing on top, soft tubing in hidden void underneath.
Acrylic detailing, sheeting and Gadget Joe and sponsor logos embedded throughout desk courtesy of Admodz
Pine top, MDF treated Carcass, Chrome Legs, Acrylic panels, Safety glass and sealants.
Main system will be white, blues and blacks. Test bench will be red, purple, black, orange.
Layout Sketches:
Build Poster with sponsor list:
Original Renders:
  #2
Old 12-02-17, 12:04 AM
Davva2004's Avatar
Davva2004 Davva2004 is offline
OC3D Elite
Intrigued! Looking forward to this build.
__________________
  #3
Old 12-02-17, 01:10 PM
SuB's Avatar
SuB SuB is offline
The Webmaster
huh, someone from my hometown. Welcome to the forums. interesting build
__________________
Gigabyte Z390 Aorus Pro | i7-8700k | 32GB Corsair Vengeance 3000Mhz DDR4 | nVidia RTX 2080Ti | Creative Audigy Rx | 1Tb Samsung 970 EVO+ M.2 | 1TB Samsung 860 QVO | 2TB Seagate Barracuda | Corsair RM850 | Fractal Define S | Noctua NH-U14S | Roccat Kone Optical - Navy Storm | QPad MK85 Pro w/ Cherry Red MX | DELL U2413 + 2 x U2412M | AKG K702's | AKG K7XX S/N#000016 | Beyerdynamic DT770 Pro 250Ohm | TM Hotas Warthog Stick and Throttle | Saitek Combat Pro Pedals | TrackIR 5 | TrackClip Pro
Notice: Don't feed the trolls!
  #4
Old 15-02-17, 09:30 AM
Newbie
Will be starting on building the desk within the next 2 weeks, ordered the materials and the components from alphacool/aqua-tuning will be due to arrive shortly also!
  #5
Old 15-02-17, 09:31 AM
Newbie
Hello SuB! dont often bump into people from Grimsby! Do you still live in Grimsby or have you moved onto better things!
  #6
Old 15-02-17, 09:36 AM
Newbie
Updated Sketchup files with a rough representation of the final appearance and measurements of the desk itself, Parts from aqua-tuning and alphacool are due to be delivered so will be updating pictures accordingly as they arrive and when work starts on the desk build!
  #7
Old 15-02-17, 01:28 PM
SuB's Avatar
SuB SuB is offline
The Webmaster
Hey Nah I moved a couple years ago to Cambridgeshire to work for a Games Dev Life changing opportunity so had to take it Not a regret since moving, must be said.
Grimsby is nice enough, but if you wanna succeed in most modern careers you have to look a bit further afield, it's full of people who just seem to want to drag the place down these days
__________________
  #8
Old 06-04-17, 08:53 PM
Newbie
New updated pictures of the components sent over by Alphacool and Aquatuning! The chrome components really are stunning!
Including XPX Chrome CPU Block
Alphacool Eisbrecher Pro XT45 240mm Full Copper x2
Alphacool Eispumpe- VPP755 x2
Alphacool RX480 Gpu Block and Backplate
Alphacool Eisbecher Lite 250mm Plexi Res x2
Alphacool Susurro Fan 1700rpm Black/Blue edition x4
Alphacool Eisdecke D5-Plexi x2
A whole Plethora of Alphacool fittings and fixings with brackets
13/10mm PETG 80cm x16
and much more
  #9
Old 07-04-17, 02:57 AM
Surfie's Avatar
Surfie Surfie is offline
OC3D Crew
Wow.... This project has really got my creative juices flowing. Great concept man!
__________________
What we've got here is; failure to communicate...
  #10
Old 07-04-17, 04:20 AM
Excalabur50's Avatar
Excalabur50 Excalabur50 is offline
OC3D Elite
Should be an interesting build to watch
__________________
DRAGON'S MIST
NZXT Phantom 630 White=AMD Ryzen 1700X=MSI X370 Gaming M7 ACK=Intel Optane SSD 9 480GB PCIE=32gig 3200Mhz GSkill Flare X= MSI GTX1080 Seahawk X=NZXT Kraken X62=MSI MPG341CQR=MSI GK80 Vigor=Corsair Force LS 960GB=Cougar 700M=EVGA Supernova 850 G2=White Sennheiser Game One=NZXT Hue+ with Aer RGB fans and RBG strip=Pioneer BDR-209D=Windows 10 Pro=Thrustmaster T16000M HOTAS=Corsair MM800 RGB CE
Tags
alphacool, aquatuning, mayhems, radeon
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
